drop resistance
any suggestions how to pik screen protectors?
temepered glass,
3 packs ??
i always go with zagg shields, mainly because Best Buy will put it on for me.....i suck at putting them on. plus there is a zagg booth in the mall near me that will install and replace the screen protector once for $7.
i hear that whitestone is really good and they have an apparatus that helps you install it with zero bubbles.
as far as cases go i have a spigen tough armor case on my note 10+
https://www.amazon.com/gp/product/B07SX62YQ7/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
otterbox also makes some really rugged cases as well.
Having trouble transferring files to my pc
I'm looking for a way to move all my photos onto my PC. I was setting up to use Bluetooth, but I could not find a way to copy more than one file at a time, and I have several hundred to handle. (Moving would be better, but copying then separately deleting the source files would be okay.) Any suggestions?
Yep! Use a file manager.
If your Android device and computer(s) are on the same Wi-Fi network, it's a trivial task with a good FM; my favorite is MiXplorer Silver. I move files around all day, to and from various Android devices and Linux computers. Piece of cake! :D
Please see this post for more info. Basically, your computer has to be set up for networking, i.e., you must 'share' its hard drive(s) and/or its external drives. Then, via Wi-Fi, you simply use a FM to move files in either direction.
Let us know if you have any questions!
Anyone know of any NON voice assistants?
Is it not possible to just turn off the voice recognition part? I played with it 3 years ago and mostly interacted with it by typing. In fact I don't think I ever actually used the speech activation, though I occasionally asked a question verbally just to test it.
Unfortunately I can't say anything about the current options, since after a couple of weeks I decided that it did nothing that I wanted and so disabled it, turned off all of the data logging that was enabled when you turn it on (but isn't disabled when you turn it off), and haven't touched it since.
P.S. I'm glad to say that I've never seen anyone in real life speaking to it in public, or even in a private setting. I'm with you completely in that I think this would be a horrible thing to inflict on the public sphere.
I have seen people talking to their devices.
Yes.
I am the one that will make noises in the background, and say inane things to throw it off.
I am just that sort of guy.
Polices S10
Bonjour,
Je souhaiterais savoir s'il était possible de trouver quelque part des polices gratuites pour changer un peu de celles installées par défaut.
Auparavant, si je me souviens bien, on pouvait en télécharger et changer comme on voulait.
Maintenant, ce que je trouve, soit c'est payant soit ce n'est pas compatible.
Est-ce que quelqu'un pourrait m'aider ou aurait une solution ?
Cordialement,
Bonne journée.
welcome to AF!!!!!!!!!!!!!!!!!!!!!!!!
use google translate. just type in your post and then copy and paste the translation here.
google translation of your op:
Hello,
I would like to know if it was possible to find some free fonts somewhere to change a bit from the ones installed by default.
Previously, if I remember correctly, you could download and change it as you wanted.
Now, what I find, either it is paid or it is not compatible.
Could someone help me or have a solution?
Regards,
Have a good day.
what phone do you have? my samsung note 10+ you can go into the samsung store either thru the phone settings or directly in the samsung store. there you can get different fonts.....not sure on other phones though.
New Game: Bubbles Pop Infinite 2020 (Version 1.0.3)
What's this game ?
"Bubbles Pop Infinite 2020" is a casual game for Android. The objective is simple:
  • survive as long as you can and make your best score to get your place in the top 15.
Bubbles will appear randomly and your mission is to explode them by tapping on it.
It will be faster and faster with the time.
But you can't tap as you wish. To explode them and get points, the bubbles and
the borders must have the same color at the moment you tap them.
Borders colors also change randomly, faster and faster with time
Tapping a wrong bubble will give you penalties. Your reflexes, accuracy and calm will be needed.
Game rules ?
  • A bubble explodes if it has the same color as the borders when you tapped on it
  • Each exploded bubble gives 1 point
  • If you tapped a bubble whose color is different from the borders color:
    • 1 random ball is added
    • 1 point is removed from your score
  • If the number of bubbles reaches the max quantity, it’s a Game Over
How to download it ?
You have to way to get the game.
The first one will help the game to get a better place when people look for it.
I'm grateful if you can use the option 1:
  1. you can look for "Bubbles Pop Infinite 2020" on the Play Store
  2. you can use this link directly: https://play.google.com/store/apps/details?id=com.amandin.bubblepup
More Info ?
For more info and be aware of any new updates, you can follow:
Video promo
Screenshots
This is nice, I have something new to enjoy with
Samsung Galaxy Note 9 — ADDING NEW RINGTONE TO S6
Hello:
I'm trying to add a new sonnerie from an MP3 file. I go to Settings/Ringtone and scroll down to "add from device storage" when I click on this I get a window what shows my gmail address as well as my yahoo address. I click on this and then it goes to "My drive choose an item" then I clock and it shows, my drive, computers, shared with me, starred, and recent. No matter which I choose I can't find the file that i'm looking for, it's in my download folder. But it won't let me find it by doing what I mentioned above
Hope you all can help.
thanks
Hope you can
App Inventor How to pass the Selected Image To ImageView From ArrayList
CardView Been clicked and gallery opened, Selected an Image, I'm trying to pass the image selected from the gallery and pass to ImagePreview inside the CardView , the cardview is generated via ArrayList. I'm getting the error like delivering a result
java.lang.RuntimeException: Failure delivering result ResultInfo{who=null, request=123, result=-1, data=Intent
Filter
