English App: Learn English for kids 1st Class English
Android App to learn English for kids, it is a first class English for kids, it provides several wonderful lessons for kids to help them learn English language (learn ingles) with the support of spoken English (in basic English level).
Get it Free from Google Play: Learn English for kids 1st Class English - Apps on Google Play
Buy no Ads version: https://store.flash-toons.com/product/android-app-learn-english-for-kids-1st-class-english/
There is 8 learning game for kids in this "Learn English" App: greetings, name and answer, familiar animals, body parts, classroom parts, different drinks, family members, and quizzes.
Math App: Math Exercises Math Drills Multiplication Table
This app can generate endless random math drills, math worksheets grade 1 , math worksheets for grade 2 , math worksheets grade 3 , and math worksheets grade 4.
Get it Free from Google Play: Math Exercises Math Drills Multiplication Table - Apps on Google Play
Buy no Ads version: https://store.flash-toons.com/product/math-exercises-math-drills/
Samples of its math drills: Specification of the even and odd numbers, Numbers Multiplications (math drills multiplication), Comparisons, Addition Subtraction, and Fraction multiplications (multiplying fractions).
Mediascan file in hidden folder
Hello,
I'm new to Android Development, and I'm encountering a Media Scan issue, I have a gif file, which saved in a hidden folder(.foldername), and when I executing MediaScan, the log shows [.nomedia], and null uri was received, when I move the gif file to non-hidden folder, everything works perfectly, so I am wondering is there any ways that makes MediaScanner able to scan file in the hidden folder?
Thank you guys very much.
Accessories Zerolemon 10K Battery Case
https://zerolemon.com/products/galaxy-note-20-ultra-battery-case-10000mah
I have used Zerolemon's battery cases for years. I am a Galaxy Note series user.
The Note is a powerful device and oftentimes I am out in the wild with no access to shore power.
That's where this case comes in.
I only get the 10K cases and, despite the bulk, I can continue to use my Note 20 in max performance mode out on locations with no worries about losing power. I was able to squeeze about 2 full charges and had some residual charge left to get me back to about 43%. This is with discharging the battery down to less than 10% (usually I would charge at 9%).
The older cases did not allow DEX mode, but with the Note 20 Ultra 5G, you can use DEX wirelessly.
I was able to use wired headphones (AKG N90Q) and still able to wireless charge.
Build quality on the case is what you expect from Zerolemon: Top rate. The rubber is grippy and protects the rear cameras. The case also provides some safety for the front screen.
I received the case with one led lit. All leds were lit in about ~2.5-3 hours. the power button on the Note 10+ last year was really sensitive in that you could turn it on inadvertently. With this years model for the 20 Ultra, the buttons has been more like it was on the Note 9.. it was not as easy to press.
Mounting the phone in the case is straightforward, and I have it down to a science.
Bonus - the Note 10+ belt clip case works with this years case! I have attached a photo showing the belt case from the Note 10+ with the 20 Ultra in it. The only way to get this to work is to have the phones screen faced into the case, so if you still have the belt clip, you can use it that way or have it as a stop gap until Zerolemon comes out with the proper one.
Caveats is the case does not allow super fast charging. This is known from the description so it is not a shock. The other caveat is bulk - if this is an issue for some, the 5K case is a good alternative.
In closing, I've used these cases for years on a few Note series devices. This is my first must have accessory when I get the Note.
Now, only if they can make one for the Z Fold2 5G.... :)
After flashing twrp recovery phone is stuck at (set warranty bit :recovery)
But y the twrp can not see my storage it 0 MB everytime I will have to wipe my phone to see it everytime I go into the twrp
https://android.stackexchange.com/questions/204831/twrp-internal-storage0-mb
"If the first solution does not open your encryption door to show your internal storage within TWRP. There is another option that should correct your internal storage issue. Format the Data, however it will cause the loss of your UserData. If the data is important to you, make a backup the /data partition. There are two simple approaches: one is through fastboot, the other is within TWRP. Since your device is a Samsung that negates the fastboot option.
  1. Boot your device into TWRP recovery.
  2. Within TWRP select the wipe option."
Select Format Data, and then slide the bar over on the bottom of the screen
This will format the encrypted /data partition erasing the encryption. A new un-encrypted /data partition will be created, thus making your internal storage visible.
Help (SOLVED) OnePlus 7 Pro - Nothing Besides Wallpaper
It was the launcher, clearing the cache didn't solve the issue, but temporarily using the nova launcher (might use it from here on out once I set it up the way I want) but just updating the OnePlus Launcher solved the issue. Since I was still getting an error message when I wanted to see the overview.
Big thanks!
In Addition: It was probably caused by the start since I had an update queued up. So the Launcher was so out of date with the OS version that it kept bugging out.
Only in LA!
It's been quiet for awhile in LA @MoodyBlues. Is it the smoke?
Like bees? :thinking:
Here in Arcadia, it's always quiet. My mom was fond of saying, "it's so quiet...it's like a cemetery around here..."
As for LA proper, the bad air quality has definitely affected everyday life. Its basin shape traps smog, hence its storied bad air quality. People have been warned not to exercise, or even go, outside due to the smoke. It has subsided, but it's still bad.
My cousin and I--who will never see 60 again--have been reminiscing about the old days, the '60s, with its terrible smog. We haven't seen anything this bad in decades. Even so, it's not as bad as it could be: a few days ago, Portland [Oregon] had the worst air quality of any major city in the world.
Best Buy
When you hire near minimum wage customer service personnel, you get what you pay for. :thumbsdowndroid: Most customer service metrics are measured by length/number of phone calls per hour and those asinine surveys the ask you to take 20 minutes to fill out. Quality of information no longer matters.
Switching with only new device.
I've had mixed experiences of first-party transfers so always have a third-party solution to hand.
When my wife last got a new phone we just used the manufacturer's transfer app (HTC) and everything you could expect just transferred across over WiFi (I don't think SIM cards were important for this). Very easy, no problems.
When I tried Google's transfer app to set up my Pixel 2 it failed miserably: simply would not work at all. Apart from contacts I've never had good experience with Google's backups, so I went straight to laptop-based solutions (copy the backup of my previous phone's internal user storage to the new device, used Helium to transfer most apps and data, restored SMS etc from backups I'd made before starting any of this, then tested out key apps on the new phone to make sure their data had restored OK, looked for ad hoc solutions for the one or two that hadn't). Took more work, but got everything done.
So for myself I would always prefer to have the old phone to hand (unless I've broken it I always do have it). But if I had to send the old phone away I'd always make sure I had a comprehensive set of backups of everything I could back up off it before doing so, so that if any cloud solutions failed I would have something local that I could use myself.
Filter
