Netstat not showing IP's
So when I do a netstat -an. I get no ips returned. Only streaming. Is this normal? I got a random OTA yesterday and I'm wondering if I've been hacked or being watched for some reason. even after a factory reset. This is all I get when trying to see the traffic on my phone.
Touch screen only works when charging
I'm currently trying to resolve the same issue yet I did find a couple of additional things that I haven't seen here..
1. Apparently these MT based devices are picky about power. The reference I received said use Original Charger and cable.
I believe looking up the specs and confirming your device is charging within spec is more realistic and equally effective.
If you swap out charger because it wasn't meeting spec. Then Drain battery to 5% and then apply full uninterrupted charge. Repeat 3 times total prior to regular use.
I'm about to try the above.. Be back with update
Help Samsung Galaxy Mega GT-19205
Based on my own experience (research). If anyone came across this same scenario. first if its updating BE PATIENT coz sometimes it takes almost an hour and once interrupted will result in BOOT-LOOP.
First fix is factory reset
Sure fix is through odin via pc just find the official firmware for GT-I9152.
You can also flash twrp custom recovery via odin after flashing stock firmware just disable auto-reboot option on odin (with auto reboot while flashing twrp it reboots to system and when you go to recovery its not twrp but stock). after flashing, directly hold power to shutdown. then imidiately hold power, home and vol+ keys to reboot to recovey (release power button to prevent further reboot).
I have TWRP installed and Custom ROM first i tried AOSP FINAL (Android6.0) rom. works but some apps installed turn to bootloop cause some problems like unable to launch apps and settings.
lucky to have twrp recovery I can delete the exact folder of the folder of the app i recently installed. (research how to)
Now I decided to use ResurrectionRemix (Android7.1) rom which is my favorite and installed on all of my old samsung devices. like s4 and note2.
but on this GT-i9152 the RR rom has no final build. left with one bug.
'BLANK SCREENSHOT' but they added a screenshot app. so far this is what I'm using until now on my gt-i9152.
Help Strange new fault
... It only happens when I press play on spotify with the lead in. last week it was fine, then some updates later and its not. ....
Are you stating Google Assistant is automatically starting up when you start the Spotify app?
If so, go into your Settings >> Apps menu, find and open the Spotify app entry, and look in its 'open by defaults' option. Use Clear defaults if needed as maybe the Spotify app was inadvertently linked to trigger Google Assistant.
Filter
