Android 10 mobile app is crashed
- Android Development
- 1 Replies
That often means that app is not compatible with Android 10....
Contact the app developer to fix it
That is built into the OS. You'd have to root the device in order to change it
You can find a ton of these types of things on Amazon and Aliexpress:
It's the Settings app itself, there are no user options menu to alter it's appearance or functionality. Look through the entire Settings >> Apps >> Settings menu to note what's there.
Use Clear data on the Settings app, and then see if you can enable Developer options normally again.
why do we have to save the saints? are they really saints? can i play as the ninjas? that wold seem like more fun.
Yes, I definitely need to draw a line, but gauging how much I'll recover isn't a factor. I'm in the house I will die in, and at that point my daughter gets it, and must keep it in the family.In any sort of face lift / remodel / upgrade of a home, one has to draw a line somewhere. Otherwise, you can easily invest more than you will ever recover.
Definitely. My imagination ran wild; I'm glad my better judgment kicked in. And you're right, the bathroom will look good with its new fixtures--and fresh paint. We can always do more later.Your bath with new fixtures will look sharp. It's not like the project can't be revisited at some point. A little here and a little there over time is the ticket. Steady wins the race.
Yes, but it's nice, right? I mean, it's your home, and it has been for so long you're remodeling its remodels! Besides, you're so handy, I'll bet you get a lot of satisfaction out of doing the work yourself. Much like learning how to repair cars, remodeling is something I never got around to.I've lived in my old house for so many years that I'm now remodeling my previous remodels.![]()
do you still have the phone?Oh man! hahaha! I'm revisiting this thread after so many years! We are in the pandemic era and phones are so much faster today! I hope everyone on this thread is alive and safe.. and that you sorted all your ROM problems![]()
Perhaps it is not compatible with your device?
Apps that are not compatible wont show up if you are using the Google Playstore app.
https://play.google.com/store/apps/details?id=com.onepunchman.ggplay.sea&hl=en_US
