How can I completely remove "Do not disturb"
Removing any shortcuts to it from the notification pull-down might reduce the risk of accidental activation
Yeah, it's all too easy to accidentally trigger that mode from the Quick Settings pull-down. I'm willing to bet that's what happened.
@andfo to remove it, swipe down from the top of the screen twice to expand the Quick Settings panel, then tap the little pencil icon at the bottom left of the panel. That will enter Edit mode so that you can just drag-and-drop unwanted tiles to below the "Hold And Drag To Add Tiles" label to remove them.
Permission Problems passwd adduser addgroup usermod etc.
Hello again. I now found a solution to play sound with: aplay from the: chroot-environment.
Many many thanks to the thread starter:
https://groups.google.com/forum/m/#!topic/maru-os-dev/HzqAdt2bpNw
First download this files:
asound.conf:
https://mega.nz/file/i0R2EY6D#lJUc-x-qFoBQQvHBagJu8URdaC2SFFHJweBHGtZNYr4
debian_sound.tar.gz:
https://mega.nz/file/7hBEgQBS#nWPPzzzmTUf77R3btNUqPt9wfpF4LCLOq8f77yAciKw
Now extract the: debian_sound.tar.gz to a folder on your phone.
Then from the: chroot-environment:
Code:
cp -av /path/to/asound.conf /etc
alsa reload
cp -av /path/to/sound /opt
chmod a+xrw /opt/sound
cd /opt
./sound
At next, install the play.apk and start it. It shows a: "Hello world!".
When you've started the: sound-binary you should see a: Server Started. And when you've launched the: play.apk you should see: "connected 127.0.0.1:xxxxx".
Now do this in a: Terminal in the: chroot-environment:
Code:
aplay /usr/share/sounds/alsa/Front_Center.wav
It should work! =)
Root Unbricking/Unroot/Return to Stock LG Spirit 4G
I have to agree with @ocnbrze , SOL
There are a few possibilities but the chance of success is dismissal at best. I can tell you from personal experience with one on my Samsung Note 4's. I had dm-verity and drk fails. I spent hours, and hours, and hours with no success. Until then, I had always recovered from soft bricking and couldn't face the reality of defeat. After weeks , I give up in frustration. Months later get an idea and try again and stay at it weeks but dm-verity/drk kicked my but every time. It wasn't untill two years that I finally got that phone working again.
https://www.google.com/search?ie=UT...rint-us&source=android-browser&q=laf.img+file
My suggestion is dont waste your time :(
Simple reliable photo organizer
Also, you may already have a basic photo management app on your phone. Most file manager apps have the ability to toggle between things like list view or icon view so when viewing the folder where you store your photos the icon view is a basic photo manager.
Also, the Settings >> Storage menu includes an integral, very rudimentary file manager, and it's in any Android phone. While it lacks the feature set in a third-party app like Simple Gallery Pro, you can do basic functions like copy, move, and delete.
Can you hide any app with a dialpad code?
Android includes a couple of features that might be viable workarounds for what you're asking.
One is Pinning, where you lock the screen to only show a chosen app:
https://www.newstalk.com/the-pat-ke...nning-on-android-and-should-you-use-it-555067
The other is Guest Mode, where you enable it so there's a secondary, isolated user account that's separate from your user account:
https://lifehacker.com/how-to-set-up-guest-mode-on-your-android-1835913254
Apps Setup android studio project with a backend
Hello, I never used android studio before and i have an assignment where i need to develop an app with Jersey.
My teacher said "The Android application and the rear part (in Jersey) communicate through the network. The rear part in Jersey will expose the resources that your android application needs, which will send POST / GET / ... requests to consume them. I don't understand what you want to do to "link" the two."
I'm a little confused about how the two parts are communicating in a project. I created a fresh one using the basic template android studio is offering me but from there I dont really know where to start to create a backend.
What is the next step?
Google Assistant... Calling on speakerphone
I've had this exact issue on every Samsung android device I've owned for the past 5 years (Galaxy S7, S8, S9, Note 9, and now S20 Ultra). I've even spoken with Samsung directly and they tell me "That's odd, that doesn't happen to anyone else. It must be your bluetooth device". I've had 8 bluetooth devices in that time, and it happens with all of them.
This phone is brand new. I've had it 3 days. First call I made was via bluetooth, and it did it immediately.
This seems like a small problem, but consider that I'm a truck driver, and to make hands free calls is a pretty big deal. I have to interact with the device itself every time I make a call while the screen is off and locked. If the screen is on, it's not an issue. Why being locked has anything to do with it is a mystery though.
Oh, and notice I specified Samsung devices. I did have an LG G6 between the S8 and S9, and it didn't do it with that phone.
I think I'll call Samsung again since they can't blame the bluetooth device anymore
Filter
