New Game: Mind Games Pro (Version 3.1.9)
- By Kors_Santos
- Apps & Games
- 3 Replies
I'm sorry for my repeated comments. As there is something wrong with my internet.
I finally fixed it very early this morning...turns out it was caused by me turning off an overlay for a custom navigation bar app yesterday. I needed to turn off an overlay due to a Chrome issue I was having where I was unable to select an answer to a permissions request - I was in a hurry so I turned off all overlays and didn't get around to debugging it properly lol! Thanks anyway for attempting to assist!What application are you running when you see this toast message?
Or does it pop up randomly with any app you are using?
I have only seen such a message if I am using a memory intensive app, and something running in the background stops due to the system shutting it down to distribute memory to the new app.
Example (from a 1GB device that I have):
I use a firewall app that runs all the time.
If I start a game called Narcos: Cartel Wars, it will often make the system close the firewall app.
This will cause a similar message to appear, because the firewall is designed to run constantly, yet the system has closed it.
Do you have any user apps that are supposed to run constantly- that could be getting shut down while using other apps?
read this thread:What does this mean exactly
It happened one other time. I don't know alot about phones but I actually suspect that my phone has been screwed with. I think somebody else is getting my messages and voicemails. I'm gonna try safe mode
I rarely visit this board any more, so I didn't see your post until now.I'm guessing that it's the file manager, not the browser, causing this.Will Brave create these .org.chromium.Chromium files? I have 2 listed in my phone and have never seen them before today after using an Android File explorer app from Play.
I made the mistake of installing Weather Home app on my S7 edge and when I go to uninstall it, the uninstall button is grayed out and I can't uninstall it.
Additionally, a brand new bunch of bloatware apps (News, Market, Videos, Personalize, Games) invaded my phone and I can't find any way to get rid of them. They don't show up in Settings->Apps and when I hold them down, all I get is a menu with edit, widgets and app info options. How do I get rid of this crap and how can I prevent further invasions like it.
