When watching videos
- Smartphones
- 5 Replies
Yeh, can see a pause/play button in the centre. Which usually dissappear when the video is playing.
Yeah stays there when video plays
Thanks for your response.If you look in your Settings >> Accounts >> Google menu that will show the Gmail address your phone is set up as its primary I.D. Things like your Contacts and Calendar will sync with that online Google account. Your email app (or apps if you use more than one) will tend to default to that primary Google account but not exclusively so any email app being just its own email client can be re-configured to use any email service as necessary. But getting back to your original posting, if you've lost access to that original Gmail account and that's what your phone was originally set up to use, you need to go into that Settings >> Accounts >> Google menu, add your personal Google account and remove the old one. This probably won't be a seamless change though so be sure to back up all your data and files. It's a matter of changing user accounts so it's not trivial.
https://support.google.com/accounts/answer/1721977?co=GENIE.Platform=Android&hl=en
Once you do change your phone over to your own Google account, than things like the Play Store will be tied to your account..
So those are stripped down versions?
I got an Android update last night and that fixed the syncing issues I was having. I think that with this second update so close to the previous one that it was an issue with the update.Yeh, many Android music players can use M3U as well as PLS.
Can you confirm if your Windows software is actually transferring the M3U playlists along with the songs to your Note 10+?
if the ring app used to work on a locked screen before, then it might have been an update that caused it to not work. you may have to contact the developer and see if there is a work around or not. or you may have to wait for a further update that will hopefully fix it.I have a Galaxy S9 and I have looked everywhere to find out how to get notifications when my phone is locked. For example I have a ring doorbell and if the phone is locked I get a sound notification but I can't see who is there. If my phone is unlocked I can open the app and see who was there it used to work when the phone was locked.
How can I get sound to work especially for YouTube?
Welcome to Android Forums, peteroogle!Sorry it's my S9 plus phone that's been hijacked because of hateful firestick
I am a test drive sort of guy.Are you talking about the phone or your dating technique?
Yes Rashr APK on the markett will flash (CWM.img by hroark13) will flash to recovery partition. Flashify wont 'accept,' SU rights/or grant full proper su. Unless Flashify by (Christian Gollner) has been updated and does now. This is a 4 yr. old thread and 4.0.3 JB running device. So APKs and said APK tool functions may have been updated by the Applications developers. J011y Xp!3r!m3nt stock modded and optimized ROM built by The one & only bcrichster A.K.A The Rominator has blessed this device with and to my knowledge ONLY customized OS built off of my ZTE Concord 2 stock ROM full nandroid backup. Please thank these fine devs of recovery, ROM and root tools Kingo Root and Rashr.
