Issue with Zip Code Validation on Google Play Console Account Creation
- By Unforgiven
- Ask a question
- 1 Replies
I see you are entering a California address while indicating your are in the US Virgin Islands. This is probably the issue.
. I only have 1 google account on the phone, and i don't think it has anything to do with it, thanks.i hadn't started odin though,i was in the point of loading the md5s until i saw that there was a CP md5 which is not possible since my tab is the wi-fi version so technically there was no install going on when i booted out of it
I'm not familiar with your new Moto G but I did find this information about using Smart Lock on your phone. I hope this link will be the answer for your trusted places and devices. Smart Lock - moto g23| Motorola Support ROE
I just figured out the trick. You have to install just the AP BUT invoke the download mode by the recovery menu. Don´t enter the download mode using the keys, enter using the recovery menu and works!Hi,
I have a serious issue with my Samsung Galaxy S8, 64 GB, dual sim. My phone has stock android, never rooted, never modified in any way. I run it in Australia but got it from overseas. After a system update (sometime in December) my phone rebooted (precisely on 29/12/2019), and after the reboot it got stuck at the android logo. Typical boot loop issue, so far so good.
Immediately after, I managed to boot into recovery mode with the intention to wipe the cache partition or do a factory reset, but neither functions worked. In fact, not a single function in recovery mode works. I can scroll up and down and select any option, but without actually executing the functions. And on top of that, after a few seconds the recovery mode freezes and I can't do anything but restart.
The only useful info in recovery mode is the following (on the top part of the screen):
"Android Recovery
Samsung/dreamltexx/dreamlte
/PPR1.180610.011/G950FXXU6DSK9" (please note that "G950FXXU6DSK9" is what it says there now, after flashing this particular firmware - see below. But the error messages were the same even before flashing).
and below, in the output part of the screen:
"fail to open recovery_cause(No such file or directory)#
Reboot recovery cause is [UNKNOWN]
Support SINGLE-SKU
File-Based OTA
Supported API: 3
E: unknown volume for path [/odm]
E: unknown volume for path [/vendor]
verity verification failed...
E: [libfs_mgr]is_dt_compatible(): firmware info was not valid : '/proc/device-tree
/firmware/android/compatible : no such file or directory"
When I attempt a factory reset (or any other function in the recovery menu), I get the following error message:
"wiping data...
formatting /data...
formatting /cache...
data wipe complete.
Apparently the firmware "G950FXXU6DSK9" doesn't work. So I got myself Odin (Odin3_v3.13.1) to flash a working firmware but cannot, for the life of me, figure out the right firmware - mostly because I don't know the right PDA and CSC.
In any case, here is the Odin log:
G950FXXU6DSK9_G950FOXM6DSK9_SMA
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<OSM> Please wait..
<OSM> Leave CS..
<OSM> Please wait..
<OSM> Leave CS..
<OSM> Please wait..
<OSM> Leave CS..
<ID:0/005> Odin engine v(ID:3.1301)..
<ID:0/005> File analysis..
<ID:0/005> Total Binary size: 5843 M
<ID:0/005> SetupConnection..
<ID:0/005> Initialzation..
<ID:0/005> Set PIT file..
<ID:0/005> DO NOT TURN OFF TARGET!!
<ID:0/005> Get PIT for mapping..
<ID:0/005> Firmware update start..
<ID:0/005> NAND Write Start!!
<ID:0/005> SingleDownload.
<ID:0/005> sboot.bin
<ID:0/005> param.bin
<ID:0/005> up_param.bin
<ID:0/005> cm.bin
<ID:0/005> boot.img
<ID:0/005> recovery.img
<ID:0/005> system.img
<ID:0/005> userdata.img
<ID:0/005> modem.bin
<ID:0/005> Transmission Complete..
<ID:0/005> Now Writing.. Please wait about 2 minutes
<ID:0/005> Receive Response from boot-loader
<ID:0/005> modem_debug.bin
<ID:0/005> cache.img
<ID:0/005> omr.img
<ID:0/005> RQT_CLOSE !!
<ID:0/005> RES OK !!
<ID:0/005> Removed!!
<ID:0/005> Remain Port .... 0
<OSM> All threads completed. (succeed 1 / failed 0)
Here is what I know:
- Model of my phone, as seen on the back of the phone case (SM-G950FD)
- region of my phone, as seen in the download mode (XSG - United Arab Emirates).
- my IMEI, as seen on the back of the phone case
- my phone serial number, as seen on the back of the phone case
- Chipset: Samsung Exynos 9 Octa 8895, obtained via IMEI.info
- OS: Android 7.0 Nougat, Android 8.0 Oreo, obtained via IMEI.info
- I can enter the download mode
- I can enter the recovery mode, but not do anything
Here is what I don't know:
- my exact PDA
- my CSC
- and therefore, my exact firmware
Here is what I have tried, unsuccessfully:
- used the most current version of Kies; however my device is not supported.
- used the most current version of Frija (v1.4.2); however I got "error 102. unable to find firmware"
- downloaded and successfully flashed 3 different firmware versions, obtained from sammobile.com. these 3 versions are:
G950FXXS6DSL2_G950FOXM6DSK9_BTU
G950FXXU6DSK9_G950FOXM6DSK9_BRI
I have flashed AP, BL, CP, and CSC. I did not flash HOME_CSC. Then I tried also with HOME_CSC, but no difference.
however after successful flashing, the outcome in recovery mode was unchanged. I still couldn't use any of the recovery mode functions, and I still got the exact same error messages.
I also tried flashing G950FXXS5DSI1_G950FOXM5DSHC_XSG, which at least had the correct country code (XSG), but this one I couldn't flash using Odin, so I went back to a previous one (G950FXXU6DSK9)
Does anyone have any idea what my error messages mean, and how to overcome them? Can anyone tell me the exact firmware I have to use to get this to work again? Or is this not even a firmware issue?
class DetectorActivity : AppCompatActivity() {
private var cameraExecutor: ExecutorService = Executors.newSingleThreadExecutor()
private lateinit var cameraView: PreviewView
private val imageCapture = ImageCapture.Builder().build()
override fun onCreate(savedInstanceState: Bundle?) {
super.onCreate(savedInstanceState)
setContentView(R.layout.activity_detector)
cameraView = findViewById(R.id.CameraView)
val captureButton = findViewById<ImageView>(R.id.CameraButton)
startCamera()
captureButton.setOnClickListener {
val imageFile = File(externalMediaDirs.first(), "${System.currentTimeMillis()}.jpg")
val outputFileOptions = ImageCapture.OutputFileOptions.Builder(imageFile).build()
imageCapture.takePicture(outputFileOptions, cameraExecutor,
object : ImageCapture.OnImageSavedCallback {
override fun onImageSaved(outputFileResults: ImageCapture.OutputFileResults) {
// Image saved successfully
Log.d("DetectorActivity", "$imageFile saved!")
override fun onError(exception: ImageCaptureException) {
Log.e("DetectorActivity", "Image capture error: ${exception.message}", exception)
private fun startCamera() {
val cameraProviderFuture = ProcessCameraProvider.getInstance(this)
cameraProviderFuture.addListener({
val cameraProvider = cameraProviderFuture.get()
val preview = Preview.Builder()
.build()
.also {
it.setSurfaceProvider(cameraView.surfaceProvider)
.setCaptureMode(ImageCapture.CAPTURE_MODE_MINIMIZE_LATENCY)
.build()
val cameraSelector = CameraSelector.DEFAULT_BACK_CAMERA
try {
cameraProvider.unbindAll()
cameraProvider.bindToLifecycle(this, cameraSelector, preview, imageCapture)
} catch (exc: Exception) {
// Handle exception
}, ContextCompat.getMainExecutor(this))
override fun onDestroy() {
super.onDestroy()
cameraExecutor.shutdown()
Samsung I9190 Galaxy S4 mini
This looks like Googles discussion forum for Google Chrome:
Browse the Google Chrome Community - Google Chrome Community
support.google.com
Is that what you were looking for?
1. if you read the reddit post, the very 2nd comment which is from the op who said that this is only for samsung's web browser. it does not exist in chrome.Hello,
In Samsung internet browser there is an option to disable pull down to refresh, source
1. How to disable pull down to refresh in Chrome browser in Samsung phone?
2. Is there a main phone setting that can disable all apps pull down to refresh in Samsung phone?
Thanks
so in twrp you will not find the term nandroid backup. but it is a very common root terminology that you should familiar yourself with. a nandroid backup is just that a backup. in twrp it will ask you what you want to back up. you should at the very least backup system, data, and boot.How can i make a nandroid backup? I have a TWRP 3.4.0.0 and on "backup" i don't see "nandroid"
A soft reset worked. Thanks!It could be a firmware glitch that a soft reset would likely fix. The sad fact is, phones are not designed to last forever and the problem could be age related.
Well in general you can't, but there are occasional exceptions, e.g. there are a small number of Sony devices you can install Jolla's Sailfish OS on (which is a descendant of MeeGo rather than Android), or Ubuntu Touch which has a longer list of supported phones, but mostly older devices.
You can have a go at building such things yourself, e.g. Jolla make resources available if you want to try to build a version for another device. But there will be a learning curve before you can try this.
On Pixel 6 with latest software it does not have this option. The only thing under Backup is to turn it on or off, no folder selection sliders available.Open Photos
Upper right hand corner go to Settings
Then go to Backup
Then select Backup Device Folder
Then turn Screenshots off (I have screenshots backed up turned on - see photo below)
