Does Verizon price match phone prices?
yeah if anybody price matches that would be Best Buy.....totally agree.
There are 4 options I can see:
1) See whether there are any theming options (including night modes or similar as well as any actual theme options LG provide) in the device settings which have an affect in this. I don't have this device or any LG so don't know what options there might be, but I can imagine some device theme/display setting interacting badly with your message setting, in which case changing that (or even toggling it to something else and back again) might correct this.
2) See whether there is anything at all in the app's settings that changes this (yes, I know you've looked, just trying to cover all possibilities).
3) If the problem is due to an incompatibility between old (Android 8) setting and LG's "new" Android 9 system or apps then deleting those settings (i.e. resetting the app to defaults) might fix it. So you could start by force stopping the message app and clearing its cache, or clearing its cache and rebooting. More likely to work is clearing the message app's data. Unless LG are doing something very weird and non-standard that should not affect your messages: there's a system database that stores those independent of which SMS app you are using, so clearing data for the message app should only affect the message app's settings. If you are worried then back up your messages first (probably not a bad idea anyway), but I've cleared data for both system and third party message apps on other phones without losing messages (on my phone, running Android 10, it's the system app "Phone and Messaging Storage" which actually stores the messages. On other phones I've owned there was a separate "Message Storage" app. So don't clear data for any app that has "message" and "storage" in the name, because that will erase your messages).
4) I know you said you didn't want to, but the final option is to use a third party app. Personally I think there are several which are better than any manufacturer's own app that I've ever used, so I never use the built-in app, but it's your preference. But if nothing else works, this will.
package com.trashysofts.auct
import android.content.Intent
import android.os.Bundle
import android.util.Patterns
import android.widget.Toast
import androidx.appcompat.app.AppCompatActivity
import com.google.firebase.auth.FirebaseAuth
import kotlinx.android.synthetic.main.register_layout.*
class RegisterActivity : AppCompatActivity() {
private lateinit var auth: FirebaseAuth
override fun onCreate(savedInstanceState: Bundle?) {
super.onCreate(savedInstanceState)
setContentView(R.layout.register_layout)
auth = FirebaseAuth.getInstance()
buttonJoin.setOnClickListener {
signUpUser()
private fun signUpUser() {
if (emailTextSignUp.text.toString().isEmpty()) {
emailTextSignUp.error = "Please enter email"
emailTextSignUp.requestFocus()
return
if (!Patterns.EMAIL_ADDRESS.matcher(emailTextSignUp.text.toString()).matches()) {
emailTextSignUp.error = "Please enter valid email"
return
if (passwordTextSignUp.text.toString().isEmpty()) {
passwordTextSignUp.error = "Please enter password"
passwordTextSignUp.requestFocus()
return
auth.createUserWithEmailAndPassword(emailTextSignUp.text.toString(), passwordTextSignUp.text.toString())
.addOnCompleteListener(this) { task ->
if (task.isSuccessful) {
startActivity(Intent(this,LoginActivity::class.java))
finish()
} else {
Toast.makeText(baseContext, "Sign Up failed",
Toast.LENGTH_SHORT).show()
Line 1
Line 2
Line 3
this.Maybe the solution is to buy a TV that's not so crappy but thinking it could also be something I'm overlooking, issue with Airpods specifically, or a conflict with the Sonos (which seems unlikely since the problem occurs with the Sonos unplugged)
So I loved this ROM on my phone I still have the phone and it's rooted so I don't know why yours bricked when you flash su and about this fm how you say every phone has it?! If so how would one enable it for it to work on there phone? Or any phone? I'm on a LG v10 now lol
no i don't believe So
as I didnt have experience with pc, the programs I didn't even know what drivers where.
Open it again and kick out again.
I got sick, disappeared for ≈2 years as a result, came back, only to find that Guides had been disbanded.Why aren't you apart of the staff anymore
It kind of looks like a plug to me. Did you have something plugged in at the time? Or something that makes some kind of connection?hello, does anyone know what application is this? i got this from notification status bar. thanks.
So what did you do about it?I had a similar chroot error
