I have a Pixel 3 from Verizon. Back a few months ago when Android 10 came out I upgraded. Since that time when I take a photo using the native camera app I see the little thumbnail in the lower right hand corner. When I clicked on the thumbnail before the upgrade it took me to Photos app and showed the picture and all pictures that were taken on the camera.
Now when I click on the thumbnail the photo pops up really quickly but then disappears. It goes to the Photo App but the picture is not there.
If I go to the Main Storage/DCIM/Camera the picture is there.
Now I just realized that none of my camera photos are getting uploaded to the photos.google.com cloud. The last picture I had was from Sept 2019.
Any ideas how to fix this short of a factory reset? I don't want to lose all my pictures since then.
does anyone flash and root it this tablet?
Not sure if 2nd or 3rd Gen?
it is 5.0.2 V - Kernel 3.4.0+
LRX22G Build, and V49510e software
any disadvantages or recommandations?
override fun onActivityResult(requestCode: Int, resultCode: Int, data: Intent?) {
super.onActivityResult(requestCode, resultCode, data)
if(resultCode == file_req_code){
if (resultCode == Activity.RESULT_CANCELED) {
file_path?.onReceiveValue(null) //file_path is the filePathCallback
return
if(resultCode == Activity.RESULT_OK){
if (file_path == null){
return
var image: Array<Uri>? = null
image = arrayOf(data.data) //I get the error here! "arrayOf(data.data)" is underlined in red.
file_path?.onReceiveValue(image)
welcome to AF!!!!!!!!!!!!!!!!That's interesting. I have a same problem right now. OP, did you find any information for your essay? If you did, tell me where to find it.
Thanks all.Public wifi or your home? Any web protection? If it works for a bit, then halts, it sounds like something (e.g. firewall) is cutting it off from phoning home, or filtering the traffic. Especially if other wifi dependent apps continue to work.
It really does not matter which folder. The same video will have preview one time and the other time it does not have the preview. There are I think two bugs for now.
1. i mentioned
2. When the video is playing and I grab the playing bar, some time it forward frame by frame and some time it forward seconds by second.
Think andriod is cool but has bugs and inconsistencies
what help do you need? did you forget your pattern? if so then you will need to do a hard reset. before doing make sure you know what your google acct info that was originally used during setup. if not, then we will need more info. just remember the more info you give us the better we can help.Can anyone help with pattern lock?
Was the phone set up to sync its photos with a cloud service? Google Photos is the most likely possibility, but Amazon Photos, Dropbox, and various other cloud services may apply. If so, you can check the appropriate service to make sure your photos are safe before proceeding with anything destructive, like a factory reset.I am not experienced enough to choose any of the other options as I do not want to lose photos on the phone
please share your soluionويعمل 100%
I am Also finding the same as these bullshit people did not mentioned that this is SELEVISION property and without SEEVII we cannot even use this ****ing receiver.
I am trying to Hack this and 90% work have been done and I have succeeded to enter in the system as they are very clever, they locked the receiver by some hidden codes and fortunately I found the codes. Just wait for my next post.
