Help Intrusive ads popping up without any apps open! Tried everything!
- By riveraadrian
- Smartphones
- 3 Replies
Maybe you have adware installed.
Care to elaborate?
Because I believe Android-x86(a Linux OS), is very good for a PC, like other Linux OSs, and far better for a PC than Windoze.![]()
Time to get $$$ and buy dashlane premium with code LUKEMIANI.
But relative to what? The apps themselves are installed in /data/app, and keep their internal data in /data/data, neither of which you can access without root. For moving the app to work it would either require the appropriate parts of the app to be moved to the appropriate place in the SD card where the OS will look (which will only work if the phone software supports moving apps in the first place, in which case no need to risk doing it manually) or else placing links from the expected location to the new one (so the OS knows where to find things). I've been using *nix systems since 1989 and spent the early part of this decade hacking my phones, and relative paths by themselves won't solve the problems that manually moving files or folders would produce.
Can you give us some examples of what you'd be trying to find?How do I search for photographs I have NOT tagged?
So you know how to do that.Or should I just download everything to my computer
You mean the searching issue, correct?and is there a Windows program that will accomplish this for me?
It sounds like the Samsung Notes app pinning to your AOD. But I cannot be sure! Try the following:
Hope this helps.
- Go into your phones settings,
- Hit the search button and look for Always on Display,
- Go in there and select Always on Display again,
- At the bottom of the page you will see Always on Display Alerts - go in there and look for apps that are allowed to pin to the display. Switch any off you don't want.
future dunkings.....LOL...could take future dunkings with no issues
It looks like the Samsung members app icon.Yes. It's a s8+
It looks a lot like this app, whose purpose seems to be to fake your location.
So far from being a location tracker, it looks like something that would mess up location tracking.
Not major gaming, maybe some game boy games or something similar. I haven't looked into chrome books, but I'll have to.what kind of gaming? are you looking for one with a gaming graphic card? would a chromebook be something y9ou might be interested? been using them for a few years now and i love them......plus they are cheap.
Thank you are all very wonderful and helpful. I will return the battery and get a proper one. Thank you all again.
NO THEY ARE NOT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Apple phones are okay.
There. I said it.
Have you tried turning off USB debugging?
Setting>> Developer>> Turn off USB Debugging
