Help How to scan 3rd party APK's + monitor after install?
- By Billtunew
- Ask a question
- 5 Replies
Oke, I see, thank you.
Thank You for these links
that is both a hardware and software issue. you will need an app and a transmitter specifically designed for what you want. you can just want something and make it happen. i do not think that there is anything like that as far as transmitters go.something like this https://www.ceneo.pl/60207886
is it possible? sure anything is possible. did it actually happen? hard to say. sd cards can easily get corrupted where only certain data on the card can get destroyed.Hi, I last accessed my encrypted safe folder 4 days ago. Today, it couldn't be found anymore. Some pics and videos in unencrypted folders also cannot be played or shown because the "file format is not supported" (mp4 and jpg). I checked a breaching website - my google data was exposed in a breach in September 2019. Is it possible that the folder and the other data were "stolen"??
Thanks.
thanx for posting your solution.Actually, nevermind. I posted because mine wouldn't pair properly, but it turns out my version of solo2 enters pairing mode by turning on and then holding the play/pause button.
Not quite. Every Android device has an /sdcard mount point (folder) which will look like an SD card location to the system. This doesn't mean there is an SD card. Actually, in any Android phone made in the last 6 years, if it has an SD card slot, it will NEVER mount at /sdcard. The explanation why is tl;dr.the Moto G will still see the SD card as an SD card.
I'm confused, you posted under the Note 8 but then say it might be a S8.
