Help delete account
- By NightAngel79
- VIP Lounge
- 11 Replies
Thank you very much NightAngel79. Much appreciated.
You're welcome! Thanks for sticking around!
I am set.Lol, I've got that for one too but one I posted isn't my my stuff
hi~
My apps pushed to alpha test and formal release at the same date (2019/11/22) and location is Taiwan (GMT +8)
I'm curious about why the apps appears on Play store, the "Last updated" time shows 2019/11/21.
Is it time zone problem caused?
Last updated time could depend on US. time?
Thanks~~
probably i should upgrade my computer, that was so freaking out to feel the heat after running emulatorWell what computer have you got there, its specs? Are the CPU and GPU maxed out when running the Android emulator plus PUBG? Depending on what you've got, you may either need to lower your expectations of a software emulator, or upgrade your computer.
We can throw some bananas and vegan yogurt in it and find out!Does it blend?
