No static field INSTANCE of type Lorg/apache/http/message/BasicLineFormatter
Welcome to Android Forums, Andrija032!
When I tried to sent image on server, I take this error - No static field INSTANCE of type Lorg/apache/http/message/BasicLineFormatter. Can someone help me with this error. Thanks for all.
You're developing an app, correct? You'll get the best help if you post on our Android Development board, where fellow developers hang out. :)
use app on lock screen without unlocking?
https://www.androidauthority.com/best-android-lock-screen-apps-lock-screen-replacement-apps-565514/
Here’s the thing, folks. Google locked down a lot of your lock screen’s functionality over the years with newer versions of Android. Third party replacements don’t have the power they once did and you no longer have neat things like lock screen widgets (and, by extension, DashClock Widget and similar apps). The stock lock screen can show you notifications, keep out intruders, and always be on if you need it to. Unfortunately, with the lock screen minimized as much as it has been, that’s about all you can do even with third party replacements these days. We recommend sticking with the stock lock screen if you can because third party options are quickly dropping out of fashion. In addition, with biometric..."
Bluetooth BLE scan stops when advertising stops
I have an Android 6 - level 23 application running on mobile devices that both concurrently advertises and scans BLE connectionless packets.
ISSUE:
I find that when I call stopAdvertising(), the continuous running BLE scan operation is halted or stops working for 1-4 seconds, before resuming again. I know this because I can readily see the continually received ad packets every 0.10 second are not received for 1-4 seconds. This implies the scan operation is halted or stopped when the advertise operation is programmatically stopped.
How can I periodically start and stop BLE advertising without adversely messing up the BLE scanning operation?
I tried developing my application using different Android version APIs with the same annoying scan halt problem:
Android 8 level 26
Just for reference, here's some snippets of Android 6 code:
// create advertiser and save in list, so advertising instance can be stopped in future.
mBluetoothAdvertiser = mBluetoothAdapter.getBluetoothLeAdvertiser();
// start advertising!
mBluetoothAdvertiser.startAdvertising( settings, data, mBluetoothAdvertiseCallback );
// do some work...
// TESTED BAD - the call below causes the BLE scan operation to halt for 1-4 seconds.
mBluetoothAdvertiser.stopAdvertising(mBluetoothAdvertiseCallback);
AR Emoji
Well the S10 does not have notification LEDs so I find it easy to miss messages or calls. Now the S10 does have notification LEDs that activate around the camera cutouts, thou this feature is disabled at present. You can use a number of apps to activate the feature, but by nature these apps require a HUGE ammount permissions that I personally am not comfortable agreeing too.
Oh ok I didn't see that in update coming for the phone
LGV20 Not Booting, Internal Memory Recovery
Wish I could provide you with assistance but Im mot familiar with LG20's but it sounds like a hardware issue. Your Pc/Mac dose not recognized the device make it all the worse. I can speak from personal experience with a Note 4 softbrick that I spent hours and hourse and hours..... trying to fix. I spent more time that the phone was worth, not to mention all the frustration. A few years later in trying to assist a fellIw Note 4 memer on XDA, I came across a .no-verity-opt-encrypt.zip 6.1 and provided ithe link in the post. Afterwards, I decided to flash it to my old Note via TWRP. I now have 3 working Note 4's lol.
Yolk
]https://apkpure.com/yolk/com.yolk.yolkapp
now what is the yolk app? i have no idea. but here is the apk, if you were looking for it.
From the link you so thoughtfully provided:
"The description of Yolk
The yolk mobile app is a companion to the groundbreaking, innovative weekly yolk Experience TM that provides pastors and house church leaders the opportunity to share a new storytelling paradigm with their attendees. This new mobile app facilitates real time interaction by bringing modern technology into the faith experience. "Please turn off your cell phones", instantly becomes "Please keep your cell phones handy!”
The yolk app features:
Ability to browse and watch video
Interactive prayer list
Real time anonymous polling
Location based content via GPS
Viewing of church material such as sermon notes, bulletins and announcements.
To learn more about a yolk subscription for your pastor or church leader visit www.yolklive.com"
Hopefully, that answers the OP's question!
Image size issue
I'm trying to develop my first app for the play store which should resize for different screen sizes/resolutions. For some reason the spinner images are showing up extremely small for mdpi virtual device & huawei 9 on firebase. Please see attached file. The other images are very large currently because I removed the ldpi, mdpi, hdpi, xhdpi, xxhdpi and xxhdpi folders to see how it would appear with just xxhdpi images.
Any ideas why the images would appear so tiny!
How can I record a phone conversation while having headphones plugged in?
OK so this probably is not the most simple solution to your query but being a headphone jack fan I've used it several times as an effective way to record audio from my phones. Using a very common 3.5mm audio cable, like this:
https://www.newegg.com/p/N82E16882021054?Description=audio cable&cm_re=audio_cable-_-82-021-054-_-Product
and an audio splitter adapter like this:
https://www.newegg.com/p/N82E168820...21-055-_-1&Description=audio+adapter+splitter
it's then just a matter of plugging the audio-in plug end of the adapter into the phone headphone jack, and then plug a headphone into one of the audio-out ports of the adapter and the audio cable into the other audio-out port. The other plug of the audio cable gets plugged into the audio-in port of a desktop or laptop. Using Audacity, a free, Open Source audio editor available for Linux, Windows, and Mac to record the audio signal from the phone you also have the ability to do things like slow down or amplify conversations.
https://www.audacityteam.org/
So yeah, this isn't a simple solution and it requires a lot of extras, but things like the cable and splitter adapter only cost a total of less than $5.
Hopefully someone will chime in with a more simplistic solution involving just an app on your phone.
(.... and just a caveat, recording live conversations without the other persons consent may bring up privacy issues related to local wiretapping laws)
Android phones not opening videos send from iOS
We are developing a music app and the ios version can open videos sent from android but not all androids can open iOS.
All have 9.0 android
Specifically, the google pixel 3 can open them but the Samsung GALAXY S9 and S10 cannot.
Those same phones can also only upload smaller photos to our video feature and rejects larger photos but can accept larger photos for profile image.
Is anyone aware of an issue for Samsung galaxy android devices why they wouldnt be able to open a video rendered into mp4 format on an iOS phone?
From what I understand, the OS matters for the coding but the hardware can effect as well.
S9 is verizon, s10 and pixel 3 are tmobile phones and both ios phones (xs max and 6 plus) are on verizon.
Thanks in advance to anyone who might have some idea.
Katya
Filter
