Root Jelly Bean'd PendoPad
- By elio jordao
- Smartphones
- 1 Replies
hello, can anyone help me get the web address for PendoPad 10 firmware model, Model: PNDP51M10BLK.
Thank you for the help
ummmmmm why? can you be more specific? the more details you give us the better we can help.Can I get passwords to wifi
Hello![]()
Many of us own their personal websites or blogs with high quality content , and large traffic,but they dosn't have an android app for theire website , wich mean that they lose a big important traffic from app store such google play app store,amazon app store , iOs app store .
to be honest now you can creat an android app for your website in just few steps , this android tutorial will teach you how to buil app for website using android studio .so lets start converting a website to an android app , As an examp we will work on our website : nulledmobileapps an make an app to run the website as webpages inside android webview , wi will creat an intro animated splash screen for our android app , using android studio to generate icons with different android dimensions and density,working with webview settings , allow zoom In/Zoom Out , Loading webview indicator,
Material design ,working with navigation drawer ,and learn how to add responsive admob banner and how to link your app to firebase Then finally Generate Signed APK ready to publish.
Link Tutorial
Parental Control and Guest Mode have been included in Android for the past several versions and should already be accessible in the Settings menu on that Nexus 5, if you have that phone in front of you check the Settings menu. Family Link will need to be installed from the Play Store, and is not limited to just tablets, works OK on phones too. (..and is getting included into Android 10 as a system-level service).And I just stumbled upon this: https://support.google.com/nexus/answer/2865483. If I understand it correctly, it says that restricted profiles work only on tablets. That's very strange. Or am I misunderstanding this?
Yes, Ive looked every setting I can find... Nothing seems to even relate to the issueDid you follow @olbriar's suggestion to check its settings? It really sounds like an errant setting is causing this unwanted behavior.
Be sure to check its settings within the app and also in System Settings, under Notifications.
So this only happens with Samsung Internet? What about other browsers--have you tried any? If not, try that and report back.When i open up Samsung Internet and start typing, the first word is always highlighted.
I am using swiftkey but have tried the samsung keyboard but i think it is a Internet browser thing as no other app has this issue.
There's nothing wrong with what you posted.I guess this whole post was wrong to have been started in the 1st place.
I don't think anyone thought you meant those replies were originating here. You're fine!I didn't mean that I was getting those kind of email replys via here.
Hopefully, our suggestions will be useful.I have gotten them via other web pages and leave it at that.
It may mean that, but it has other meanings, too. In recent years the terms 'sugar daddy' and 'sugar baby' have come to mean men who pay young women for...well. that depends on who you believe!My understanding of the term "sugar daddy" is a female that is looking for some male with lots of money to pay for there way into the USA from some foreign country. And when they get here, who knows what they are going to do.
I will do that.Make sure you use the correct connector, micro USB or Type-C, depending on your device
Actually, I have installed Genymotion and it is 'fairly' easy to install and it works great. When I tried to install Bluestacks, my virus software alerted me to at least one or two things it didn't like (I'm not saying they were viruses, but probably something in the background it doesn't like).
S7, Adnroid 8.0 See image for full version data
Also image for data use...Data use from removed Apps?!?!?!?!?!?!?!?!?!?
is it me being uber dumb? (wouldn't be the first time)
What's occourin?
It's data that was used by those apps BEFORE they were removed. But if they were installed during that period or billing cycle, like "1-30 Sept", their data use still counts towards the total. The system doesn't keep a list of removed apps.After using the Huawei Honor Pad JD09 for a few years and being very happy with it I bought a Media Pad M6 because of the higher specifications-4GB RAM, 128 GB internal storage, holds a 256 GB micro SD card and has a faster processor. I couldn't find specs this good on an Australian seller for an 8" tablet so I got one from Gear Best who I bought the first tablet from. the first one came with a Chinese ROM and language. I changed to English, uninstalled most of the Chinese apps and sideloaded the google play store, changed to the google launcher and its great. I only have the google apps I use, unlike a local tablet which has all of them. Unfortunately this new tablet seems to be blocking attempts to use any google apps. They install but don't work, whereas Microsoft's apps including the Microsoft launcher all work fine (although the Microsoft launcher cant be set to default, have to click on it after booting into the Huawei launcher. I saw some internet site suggesting a fix using an app from lzplay, but that link has been taken down. Anyone else got an easy fix? There are alternatives: Gmail works in the email app and outlook, my photos on google photos are duplicated on one drive, the calendar is duplicated in Microsoft's, and while not as good there are other mapping options. Plus all of google works in a web browser, just less convenient. Interesting Adobe Digital editions works, but Adobe reader is "incompatible". Most of the apps I got from phone clone (from my LG phone- the Honor pad, Hauwei's old device is not compatible-go figure when they want you to update from your old device!), they are not in hauwei's store but nearly all the ones I want work ok.
Another option that's more of a kluge -- assuming you also have a smartphone if your cellular service plan includes hotspotting than you can set up your own portable, limited WiFi network. Since almost all tablets include support for WiFi, your options to upgrade to a newer one are a lot less restricted. Not an ideal situation of course, and it requires having the hotspot service running on your phone which is going to add a drain on the battery.
awesome. it is for sure handy. just used it when i upgraded from the note 8 to the note10+.I wanted to get back and thank you. The Smart-Switch work pretty much flawlessly.
You joined five months ago, in June.First of all, I am new to this forum
The one you wrote? Whose link I posted?and I didn't see an older post about this.
Yes, indeed! Which is why I asked: "Wasn't this answered a few months ago, @Liviu Zaharia? Or is this different somehow?Second, and even more important, what was valid a couple of months ago may not be valid today anymore.
Oh my goodness! Isn't that fascinating? Here I was completely clueless!The technology evolves, if you didn't know!
