Well, when you remember what you wanted to say, presumably about privacy protection, please post its details and we'll try to help!Forgot
what are you trying to do? what carrier is locked into the phone? what happened to your sim card? the more details you can give us the better.I have a Samsung Galaxy J3 Pop and it is locked and my sim card is gone to! Can someone please let me know what to do? I appreciate it!!
How do you take the cover off? There is not a notch at the bottom as some info says.
Another said put sim tool in the tiny hole to pop the cover off. There is a hole, but I don't have a tool, tried a paper clip but it was too thick. Help!
One day when starting Youtube app I got the message that I need to update the app and the next one was that the latest version is not compatible with the device anymore. So i intalled older version, menaged to open it, but now videos doesnt load at all, there are stuck at buffering forever.
I've tried installing couple of even older versions but it didnt help at all. Same thing happens in Chrome when I try to watch youtube via the website.
The built in update app says the device is already running on latest software.
Is there a way of using device with Android 6 to work with Youtube ? Some modified version of the app maybe ?
Also does youtube check server side which version of app is trying to access it, then and allows only latest clients as a form of forcing people to buy new gear ?
Thanks
Me too! My closets and cupboards are always stuffed and a huge mess! My drawers are like that, too. And my garage...don't even get me started on that...Storage problem
like or not it worksI have never liked Google Photos, and hate Chrome with a passion. I am looking for a direct wireless transfer solution to my desktop PC. Going to try the Bluetooth option, if I can find my friggin adapter....
Yes, you could have a different face per user but it won't auto-switch between the profiles based on face alone. You'd still have to activate the switcher on the lock screen to change profiles.
Hopefully lol@Cyberdev We'll find out soon.![]()
