apps - cant Access the image on the device screen"
- By faceofwin
- VIP Lounge
- 5 Replies
I found solution , I turned off my app 'dimming screen'and now can put that button! THANKS!
yeah the password is correct.Do you have the correct password?
I need to know how to get pluto tv onto my skystream box. I live in Canada where it's not available but I heard there's a way to do it. I've moved myself to Detroit through a GPS emulator but it still doesn't show up on google play
is the card formatted? how are you moving apps to the sd card? not all apps can be moved to the card.I cant open or move any files or apps to my sd card 16bit
Amen!!!!!!!!Welcome to Android Forums, Asif Ahmed Taiyeb!
Please follow the link @James L posted. Do not--repeat, DO NOT--use any one-click root method.![]()
At best, they may root your phone, but you won't learn anything from the experience. At worst, they can do devilish things you'll be unaware of. Do it yourself or don't do it at all!
Hi! I am new in Android development, I would like to ask how would be the code for an app "A" with a button to call an activity from another app "B" that is exported. If this activity give you access to sdcard files, how can I download those files or modify those files from the app "A". This would be for hacking demonstration purposes
You can try connecting a trackball or mouse to it, and use that to navigate the screen's choices. You'll need an adapter; which kind depends on which type of port the phone has, micro-USB or USB-C.The device is completely fine but cannot input the commands by touching the screen.
I'm using the Asus Zenfone Max Pro M1 running Android 8.1.0What phone and android version do you have?
