I have someone in UAE however the thing i am worried about is region sim lock of samsung, exypansys.ae mentions the device is unlocked but there's no way to find out if its region unlocked or notOfficially the snapdragon 855 won't be available in India, you could try any of these stapes though if you really want snapdragon 855
- Buy the Snapdragon 855 varient of S10 from Alibaba/baggood/amazon or any third party retailers. You will have to wait for long and pay extra for shipping and may or may not have to pay customs
- If you have any friends or relatives in US or Canada or even UAE ask them to buy the phone and send it to you or ask them to bring it with them.
Not rude at all. You're just trying to help, and I appreciate it.Yes, cracks would be easily visible.
I don't want to be rude, but you've posted about half a dozen threads worrying about whether normal use will destroy your phone. They are not that delicate: try not to drop it, sit on it or immerse it in water (or other fluids), be wary on a beach (sand and salt water), but otherwise you don't have to worry so much.
That's fantastic!You guys saved my ass. I thank you!!!!!!!!!!!!!!!!!!!!!!
you welcome....i think...LOL[QUOTE = "ocnbrze, posting: 7922017, anggota: 123763"] saya menemukan ini:
http://officialfirmwarelink.blogspot.com/2017/11/how-to-root-oppo-a39-oppo-a39-custom.html
ada tautan untuk twrp
dan hanya fyi twrp tidak tergantung pada os android, melainkan kompatibilitas perangkat. [/ QUOTE]
Thank you
it is only dumb if you do not ask a question. at least this person was brave enough to post it and have all the world to see the question.^ Dumbest question here with over 1k views and now this 1 reply.
what do you mean it stops? like freezes? errors?
As I said earlier:How do I resize a photo?
You're welcome.Ok, got it thanks for the help.
After a factory reset, unfortunately, yes. But as noted, that's the point. Like if you're selling your phone, you factory reset it first, then you know the buyer can't dredge up your data.I now know why there are no local services which provide phone data recovery as the chances would be slim to none.
I wonder if there is an issue with the Android Auto and there will be an update?Thankfully it didn't send cool cool.
have you tried a factory reset?
Thank youTake both into Boost mobile and complain. It's their network and they control it. No app will fix this issue
