WOW!
- By today
- Smartphones
- 2 Replies
The sound has a lot of depth. Doesn't sound tinny if you know what I mean. My daughter couldn't believe that sound was coming from a tablet. I'm very satisfied.
try it in safe mode first. if it still doing the same thing then i would try a factory reset to see if it is a software issue. if it is still doing it, then it is most likely a hardware issueAll of a sudden, phone started vibrating constantly for no reason. It simply never stops. If I restart it, it doesnt stop. If i power it off, it stops when it is off. The second i press the power button to start the phone, it starts vibrating non stop again.
Any idea if this is a software thing? Do you think a factory reset might help, or is it a hardware issue?
Was there any difference after the App 'Sleeping'
Knox showing 0x0 means that the phone hasn't been rooted and modified. If it was showing 0x1, that's a problem and Samsung OTA updates won't go through.
As to why the update isn't going through. Don't know for sure. One idea though, are you in the country or region that your phone was intended to be sold and used in. Is it a grey import? You could try updating it manually using Odin on a computer.
well boooo. it is currently not available for my pixelbook. but i will try this on my laptop when i get a chance tomorrow.You're welcome!
Same here, I did had the golden cartadge (sp?) Edtion with hologram sticker for Majora's Mask..."The Legend of Zelda: A Link to the Past" for the super nintendo is one of my favorite games of all time from my gaming days. Just had to throw that out there.![]()
