Accessories Cases
Ditto here, finally got my order to go thru, should be here in a couple days and this is the clear case I went with for a few reasons, like you I wanted to showcase the Aura Glow, Spigen is a brand I've used many times on many phones and they always hold up very well, and it also has a kickstand for watching video's movies, etc.... https://www.amazon.com/gp/product/B07SSW6DB2/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Now I have to decide on a screen protector, wanting something glass rather than flexible or liquid.
I got a Spigen clear and like the quality. Wish they could do something about fingerprints, though.....
Color Up - Awesome minimalist jumper game
Hi Everyone, our new game Color Up is already live.
Download Link: https://play.google.com/store/apps/details?id=com.jumper.platformer.matedevs.colorup
Gameplay video:
It is a minimalist jumper with very simple two-finger mechanics.
It has two modes by now, classic mode which includes 6 worlds with 5 levels each one. And an endless mode for each world.
Each world has its unique environment factors, for example rain, wind, upside down
We invite whoever wants/can download and help us with a review and/or feedback so we can continue improving it
Thanks everyone!
Can't mute notifications
If you can tell what app you are using perhaps someone else also uses it and can further help you with the settings. I understand about those annoying notifications and use different apps for different notifications for that very reason. I've found that my 3rd party alarm clock works best for my specific notifications as I can have loud and silent alarms with it while for regular reminders I use a tasks app or calendar app. I don't know if any of that rambling helps at all.
Email box full
Does this phone support moving apps to SD at all? Not all do, and if yours does not then that's the end of the story (apart from rooting, partitioning the SD card and using some app like Link2sd to move things).
You could try turning on usb debugging (in developer options), installing "ADB" on computer, connecting the phone to the computer and using the command (from memory - you may want to do a quick web search to check I've remembered correctly):
adb shell pm set-install-location 2
If your phone supports this at all that will make installing to SD the default. It won't move any existing apps, but if you can't move them after that then you cannot move them at all.
That's really the only thing you can do without root that will make any difference.
Android HostApduService, should it run always?
In my application, I have my own HostApduService for receive command APDU from NFC device. When my testing phone restart or when I change the default service to my app from Android settings UI, I saw my HostApduService getting created.
If I do tap to NFC device, it will continue the process and complete. At the end it will not destroy my HostApduService.
According to this observation, I think my HostApduService should always running in the device, if my application is the default service for this. Is my assumption correct?
Thank you in advance...
Any one having problems with signal?
I am on verizon and cannot get a good signal in my office. (-105) with one bar. My notification bounce back and I cannot make a call. I had no issues with my note 5 from same place and I know another with verizon without problems.
Are other having this issue or do i have a bad antenna or something on my phone?
So far all good, maybe something wrong with your only. get it checked.
sqliteOpenHelper...Unique combination of columns?
Sorry about that. Ultimately it was a string formatting issue that was causing the original error. I did implement the database with a two column primary key, which I thought was more appropriate. It works well and I'm not seeing any of the duplicates.
with that being said, I didn't need to go that route. Using UNIQUE would have worked as well. but your suggestion I liked much better.
I've been tripped up several times in regards to string formatting when it comes to writing the SQL commands.
Motorola G7play
My MotoG7 was borrowed and came with a whole lot of files are can't delete because he's got admi .Control and encrypted the phone As well. He's a neighbor and had access to my router. There's a second hidden menu, NFC and Bluetooth control by him. I see it in the background when he's ****ing around with something, catch him turning DND on/off, exporting to PC, etc. Obviously a hard factory reset is not cutting it. Any advice?
If he has access to your network, first thing is change the WiFi password, and make sure it's using WPA-PSK encryption, and not WEP or open. Also change your Google password, and enable two-factor authentication.
Is your Moto G7 rooted? If it's not rooted, a factory reset will at least clear the phone.
[GAME][4.4+] Caterpillar Run
Hi,
We created a simple arcade game, in which you need to save a caterpillar from water.
We would be happy if you try the game and leave a feedback.
Thank you.
Game's link
https://play.google.com/store/apps/details?id=com.telei.caterpillar
BLE Scan on start returning null
I have used the BLE scanner code from the Android site, but everytime when I start the Scan it returns an Null. I check for all the relevant packages and ensure BT is enabled, but the BLE scan never starts. There is a log message to check the return status, oddly the handler does not seem to be working either to stop the scan after 10 seconds.
Is there something else that is required to enable the BLE scan function to work?
All the appropriate permissions have been added into the Manifest file and this is checked via the package manager:
package com.example.blesandpit
import android.app.Activity
import android.bluetooth.BluetoothAdapter
import android.bluetooth.BluetoothDevice
import android.bluetooth.le.BluetoothLeScanner
import android.content.Intent
import android.bluetooth.le.ScanCallback
import android.bluetooth.le.ScanResult
import androidx.appcompat.app.AppCompatActivity
import android.os.Bundle
import android.widget.Toast
import kotlinx.android.synthetic.main.activity_main.*
import android.util.Log
import android.os.Handler
import android.content.pm.PackageManager
class MainActivity : AppCompatActivity() {
private var mbluetoothAdapter: BluetoothAdapter? = null
private lateinit var m_pairedDevice: Set<BluetoothDevice>
private val REQUEST_ENABLE_BLUETOOTH = 1
private val bluetoothLeScanner: BluetoothLeScanner? = null
override fun onCreate(savedInstanceState: Bundle?) {
super.onCreate(savedInstanceState)
setContentView(R.layout.activity_main)
Toast.makeText( this,"App started", Toast.LENGTH_LONG).show()
if (!getPackageManager().hasSystemFeature(PackageManager.FEATURE_BLUETOOTH_LE)) {
Toast.makeText(this,
"BLUETOOTH_LE not supported in this device!",
Toast.LENGTH_SHORT).show();
if (!getPackageManager().hasSystemFeature(PackageManager.FEATURE_BLUETOOTH)) {
"BLUETOOTH not supported in this device!",
mbluetoothAdapter = BluetoothAdapter.getDefaultAdapter()
if (mbluetoothAdapter == null) {
// Device does not support Bluetooth
Toast.makeText( this,"Device does not support Bluetooth", Toast.LENGTH_LONG).show()
} else {
if (!mbluetoothAdapter!!.isEnabled) {
// Bluetooth is not enable :)
Toast.makeText( this,"Bluetooth is not enable", Toast.LENGTH_LONG).show()
if(!mbluetoothAdapter!!.isEnabled)
val enableBluetoothIntent = Intent(BluetoothAdapter.ACTION_REQUEST_ENABLE)
startActivityForResult(enableBluetoothIntent, REQUEST_ENABLE_BLUETOOTH)
Toast.makeText( this,"Bluetooth is now enabled", Toast.LENGTH_SHORT).show()
else{
Toast.makeText( this,"bluetooth is enabled", Toast.LENGTH_LONG).show()
scanstart.setOnClickListener {
startbtscan()
val handler: Handler? = null
handler?.postDelayed({
stopbtscan()
}, 10000)
scanstop.setOnClickListener {
stopbtscan()
override fun onActivityResult(requestCode: Int, resultCode: Int, data: Intent?) {
super.onActivityResult(requestCode, resultCode, data)
if(requestCode == REQUEST_ENABLE_BLUETOOTH){
if (requestCode == Activity.RESULT_OK){
if(mbluetoothAdapter!!.isEnabled){
Toast.makeText(this, "Bluetooth has been enabled(1)", Toast.LENGTH_SHORT).show()
} else {
Toast.makeText(this, "Bluetooth has been disabled(2)", Toast.LENGTH_SHORT).show()
} else if (resultCode == Activity.RESULT_CANCELED){
Toast.makeText( this, "Bluetooth enabling has been canceled(3)", Toast.LENGTH_SHORT).show()
fun stopbtscan(){
var result = bluetoothLeScanner?.stopScan(blescancallback)
Toast.makeText(this, "Stop scanning", Toast.LENGTH_LONG).show()
Log.i("Log", String.format("Stop BT Scan\" = %d", result))
fun startbtscan() {
var result = bluetoothLeScanner?.startScan(blescancallback)
Toast.makeText(this, "Start scanning", Toast.LENGTH_LONG).show()
Log.i("Log", String.format("Start BT Scan\" = %d", result))
private val blescancallback = object :ScanCallback() {
override fun onScanResult(callbackType: Int, result: ScanResult?) {
super.onScanResult(callbackType, result)
Log.i("Log", "onScanResult")
Log.i("Log","onScanResult: ${result?.device?.address} - ${result?.device?.name}")
override fun onBatchScanResults(results: MutableList<ScanResult>?) {
super.onBatchScanResults(results)
Log.i("Log", "SonBatchScanResults")
Log.i("Log","onBatchScanResults:${results.toString()}")
override fun onScanFailed(errorCode: Int) {
super.onScanFailed(errorCode)
Log.i("Log", "onScanFailed")
Log.i("Log", "onScanFailed: $errorCode")
This is the manifest file
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
package="com.example.blesandpit">
Reference
https://developer.android.com/guide/topics/connectivity/bluetooth-le
<uses-permission android:name="android.permission.BLUETOOTH" />
<uses-permission android:name="android.permission.BLUETOOTH_ADMIN" />
<uses-permission android:name="android.permission.ACCESS_FINE_LOCATION" />
<uses-permission android:name="android.permission.ACCESS_COARSE_LOCATION" />
<uses-feature android:name="android.hardware.bluetooth_le" android:required="true"/>
<application
android:allowBackup="true"
android:icon="@Mipmap/ic_launcher"
android:label="@String/app_name"
android:roundIcon="@Mipmap/ic_launcher_round"
android:supportsRtl="true"
android:theme="@Style/AppTheme">
<activity android:name=".MainActivity">
<intent-filter>
<action android:name="android.intent.action.MAIN" />
<category android:name="android.intent.category.LAUNCHER" />
</intent-filter>
</activity>
</application>
</manifest>
OxygenOS update 9.0.17 for 6T & 9.0.9 for 6
OnePlus has begun the OTA, (Over The Air), rollout of their new stable OxygenOS firmware, 9.0.17, for OnePlus 6T and McLaren and 9.0.9 for OnePlus 6 users.
As always, there will be a limited roll out initially, followed by the global roll out in a few days.
Changelog
  • System
  • Fixed the crash issue with Screen Recorder
  • Re-activated the calling function after the network has been reset.
  • This update will improve the overall system performance to prepare for later versions
Android Security patch = August 2019
Camera version is still 3.0.16
This is the 12th official, stable, update for the 6T in 322 days
(The T-Mobile (USA) carrier minority variant has only received 8 updates in 331 days)
(N.B. OxygenOS 9.0.17 is not available for the T-Mobile (USA) carrier minority variant)
Filter
