Help Can't respond to group texts.
I am having the same issue on my Galaxy Note 9. I can't respond to group texts, but if I enter everyone's name as if I'm starting a new text it does send the message and it shows up in the thread with other messages from that group...so I guess you would say I actually can respond, but not without reentering everybody's name... I can't just type in a message and hit send. My message just turns grey and shows an explanation mark next to it.
ARcore - is it possible to make AR APP using powerful phone that is not listed in google officially
Hi guys
I have a question related to google ARcore supported Phones.
I have a Xiaomi K20 pro phone that has powerful specs to handle ARcore but it isn’t listed in google “ARCore supported devices” list.
I want to know, is there anyone here who has experience with developing a AR APP with ARcore with Xiaomi K20 pro (or any other powerful phone that doesn’t listed in the ARcore supported device list)
and is it possible to do that or not?
PS, Xiaomi k20 pro specs are exactly the same as Xiaomi Mi9 ( Mi9 is supported but K20 isn't )
Cheers.
Spinner not getting populated with database records in android
Hi. I am using Yii2 REST API. I have a table called studentrecords consisting of Id,FirstName,LastName, Class fields. I have a API which returns the json array containing stiudent FirstName and LastName. API is working fine. Now I have a android code where I use a spinner to display student names from the database.
Java:
package com.example.anitaa.studentapplication;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.widget.ArrayAdapter;
import android.widget.Spinner;
import org.json.JSONArray;
import org.json.JSONException;
import org.json.JSONObject;
import java.util.ArrayList;
import java.util.List;
public class UpdateActivity extends AppCompatActivity {
    Spinner spinner;
    ArrayAdapter adapter1;
    String url1 = "http://192.168.1.6/student/web/studentrecords/studentnames";
    @Override
        super.onCreate ( savedInstanceState );
        setContentView ( R.layout.activity_update );
        spinner = (Spinner) findViewById ( R.id.spinner1 );
        final List<String> list = new ArrayList<String> ();
        try {
            JSONArray jsonarray=new JSONArray(url1);
            for(int i=0;i<jsonarray.length();i++)
                JSONObject jsonObject = jsonarray.getJSONObject ( i );
                list.add(jsonObject.getString ( "FirstName"));
                list.add( jsonObject.getString ("LastName"));
        } catch (JSONException e) {
            e.printStackTrace ();
        adapter1=new ArrayAdapter ( this,android.R.layout.simple_spinner_item,list );
       // adapter1.setDropDownViewResource ( android.R.layout.simple_spinner_dropdown_item );
        spinner.setAdapter ( adapter1 );
When I run it then spinner is not populated witth records. How to do?
Supports-Screens
Hey I have been learning about developing games for Andriod and I just wanted check some information becuase it's not 100% clear.
Firstly the bellow two links from the Andriod Developer website both show declaring support in a different way.
The first one:
https://developer.android.com/guide/topics/manifest/supports-screens-element.html#compat-mode
Code:
<supports-screens android:resizeable=["true"| "false"]
                  android:smallScreens=["true" | "false"]
                  android:normalScreens=["true" | "false"]
                  android:largeScreens=["true" | "false"]
                  android:xlargeScreens=["true" | "false"]
                  android:anyDensity=["true" | "false"]
                  android:requiresSmallestWidthDp="integer"
                  android:compatibleWidthLimitDp="integer"
                  android:largestWidthLimitDp="integer"/>
The second one:
https://developer.android.com/guide/topics/manifest/compatible-screens-element#screenSize
Code:
<compatible-screens>
        <!-- all small size screens -->
        <screen android:screenSize="small" android:screenDensity="ldpi" />
        <screen android:screenSize="small" android:screenDensity="mdpi" />
        <screen android:screenSize="small" android:screenDensity="hdpi" />
        <screen android:screenSize="small" android:screenDensity="xhdpi" />
        <screen android:screenSize="small" android:screenDensity="xxhdpi" />
        <screen android:screenSize="small" android:screenDensity="xxxhdpi" />
        <!-- all normal size screens -->
        <screen android:screenSize="normal" android:screenDensity="ldpi" />
        <screen android:screenSize="normal" android:screenDensity="mdpi" />
        <screen android:screenSize="normal" android:screenDensity="hdpi" />
        <screen android:screenSize="normal" android:screenDensity="xhdpi" />
        <screen android:screenSize="normal" android:screenDensity="xxhdpi" />
        <screen android:screenSize="normal" android:screenDensity="xxxhdpi" />
    </compatible-screens>
Is there any real difference between the two other than that the first dose not specify density?
Second I wanted to just make sure I understand what exactly constitutes as a Small, Normal, Large and xLarge screen.
Please correct me on this:
A Normal screen is a HVGA 480x320 pixels screen. This value is the baseline for that other screen sizes.
A Large screen would be 1.5x the normal baseline.
A XLarge screen would be 2x that baseline.
and so on...
Unable to read SIM data on Samsung A50
Just purchased a new Samsung Galaxy A50.
No issues with the phone other then listed below.
It is a dual SIM phone. With SIM 1 - AT&T, SIM 2 - SaskTel.
I cannot get any SIM Data to read. My old phone (Samsung Galaxy S8) can read both SIMs perfectly fine. So the problem doesn't appear to be the SIM cards themselves.
The phone is completely functional otherwise (can place calls, text, browse, or write on this forum)
What I am trying to accomplish is migrating RoboKiller to my A50. It gives an error (see image) and I cant get it to function.
What I have tried:
Turned off data
Turned off SIM 2 (and vise versa)
Restart
Cleared SIM data (in settings)
Used 3G Mobile network
With or without WiFi (even turned off)
Is there anything I am missing?
Apps Android screen recording portion of app
I am creating a feature in an app in which the user can record their screen. So far, I've been semi-successful.
As a first pass, I tried recording screenshots then encoding them using JCodec. This worked, but the encoding was extremely slow on Android which made it unfeasible.
A second attempt was to use MediaRecorder but this records the whole screen, including the Android UI. The results are ugly and I haven't found a way to record only a portion of the screen using MediaRecorder.
So I'm looking for any alternative solutions or possibly a library that can crop video that isn't slow to process like JCodec. Any ideas?
Help Screen goes to sleep after 5 seconds
Have you tried restarting the phone? But could be a bug in the firmware though that Motorola needs to fix, because I had a very similar thing happen with an Oppo R11 once, the screen would go to sleep after 10 seconds regardless of settings, which was fixed with a subsequent OTA update
Yeah. Tried that. This has actually been ongoing for months. I really don't like this phone.
Is Poweramp hi res music player a relic to some, or do you favor Samsungs
I was never a Poweramp user. I've used Winamp through the years but it is no longer supported... at least I don't think it is. I stream SiriusXM so I don't really play my own tunes like I did in the past. I enjoy my own tunes but they were collected over a long span of time from many places. Some are so old that they are of lesser bit rate and they all have a problem of not being ripped at the same volume level. All that is eliminated with a streaming service but my library is larger than what they care to stream.
Geography. Quiz. Many tests
Install the application &#8220;Geography. Quiz. Many tests&#8221; - this is an entertaining game where you need to answer questions, guess the right answers, gain new knowledge and learn interesting facts!
Geography. Quiz. Many tests:
&#10004;&#65039; A free, smart app to test your knowledge of geography!
&#10004;&#65039; More than 2000 questions!
&#10004;&#65039; Simple and intelligible interface!
&#10004;&#65039; Questions include all geography topics!
&#10004;&#65039; Ability to choose the topic you are interested in!
&#10004;&#65039; A great way to relax and exercise your memory!
&#10004;&#65039; Interesting facts on the topic of our planet and geography!
You can study geography or prepare for the exam and assess your level of
knowledge of geography.
The questions presented in the game cover all topics and key areas of
geography.
Here you have to guess which state is located on the map, which state the flag belongs to and answer fascinating questions about the countries and states of the world.
How to play:
- Press the 'START' button and select a geography category you are interested in!
- Each topic has its own levels. Levels open when you pass and score points!
- Get points and coins for every correctly answered question!
- Points give you the opportunity to go to the next level!
- Coins give you the opportunity to use the tips when passing the quiz!
Tips:
At the bottom of each question there are 4 tips that can increase your chances of a correct answer.
&#10004;&#65039; &#8220;50:50&#8221; - use this hint if you want to exclude 2 incorrect answers to the question.
&#10004;&#65039; &#8220;Skip question&#8221; - activate this hint to get through without minus points.
&#10004;&#65039; &#8220;Audience survey&#8221; - use the audience to check, other users choose the answer option.
&#10004;&#65039; &#8220;Reset Timer&#8221; - resets the time if you need to think more!
In this quiz you will find questions from the following categories:
* Flags of the world
* Capitals of the world
* Country by contour
* World countries on the map
* Lithosphere, hydrosphere, atmosphere
* Geographical Discoveries
* Tests on the continents (North and South America, Europe, Africa, Australia, Asia, Antarctica)
* Country Population
* Currencies
* Sights
And also a lot of interesting facts about the world!
' Geography. Quiz. Many tests' - a quiz for those who want to study geography.
Have fun and you will have the opportunity to improve your general knowledge and memory!
https://play.google.com/store/apps/details?id=top.excellenceapp.engeography
Notifications
It's the fact that the tab doesn't know that you've handled them on another device. Not an android issue as such. And TBH I don't see a way of stopping it on the tab except by turning off notifications on it.
I don't know what apps you have this with, but with my tablet (also less used than my phone, and often inundated with notifications when I turn it on) I will receive notifications for new unread emails, but not for those that are read. Which is reasonable: the server tells the mail client which mails are read and which are unread, but it doesn't know which ones I've received notifications for on another device (it may know that another device has downloaded them, but it doesn't know that that device has notified me or that I've seen it). This also means that with one of my accounts both my phone and laptop will notify me of new mails unless I read it on one before the other downloads (i.e. it's the same with my laptop, not android, as with my different android devices).
With calendar apps if an appointment has a reminder set all devices it's synced with will notify me. So again my laptop and phone will both do so, and my tablet if it's on at the time (but it won't notify me of things that have been and gone in the meantime).
Without knowing what notifications you have I can't say what's reasonable. I'm just mentioning those as two examples of cases where I get multiple notifications and would expect to do so.
If you want an example of unreasonable notifications, then Facebook is exhibit number 1 (it does know exactly what you've done on any device, but is quite happy to notify you about something you read 2 hours ago on a different device or even using a different app. They don't care as long as it gets you to open their app again).
Only setting speaker volume
I've been on a quest for a long time to set volumes based on location, like at home I want certain volumes set and at work I want my phone on vibrate. I've been surprised how hard it is to get it to work right when you throw bluetooth and headphones into the mix (mostly the bluetooth).
I'd like to set speaker volume when I enter or leave these locations but not affect bluetooth volume. So I track when bluetooth is connected but getting it to work right is still elusive. I think it boils down to timing, order of when things happen, differences in when bluetooth reports as being connected vs. when the volume setting applies to bluetooth.
Is there any way to ignore whether bluetooth or headphones are active and instead just say "I want the speaker volume to be X" so that once bluetooth deactivates or headphones unplug, the speaker volume is already at the desired level? In other words, would it be possible to have tasker somehow tell android to set the speaker volume rather than generically the media volume? (possible feature request?)
Any other way to approach this problem that isn't so fraught with complexity?
Filter
