How to implement and use of Android kotlin Koin library ...!
- Android Development
- 2 Replies
yes are you right !!
im guessing you have to go thru them.........not really familiar with them though. i do not see why they would make it universal. it looks totally proprietary and you most likely will need to go them for the modules. looks like they have one for android and windows.yes but can I use any modules or just specific once?
Thank you a lot! I really missed that...You've missed something.
Go here and scroll down. I count about 38 Xiaomi device forums and 14 Meizu.
I have saw and heard scuttle but about it snd even stopped into a couple of Metro PCS . STORES AND INQUIRED ABOUT IT !! BUT HAVE ONLY GOT DIFFERENT OPINIONS ABOUT IT FROM ALL IVE ASKED !!! Sorry !! If I do finally get a positive response I will fly you a kite ok ?? If you should discover a true answer please don't hesitate to get me back in the know !! @ or ; good luck !! Have a great day !!
<?xml version="1.0" encoding="utf-8"?>
<resources>
<item name="workouttype" type="id" />
<item name="txthello" type="id"/>
</resources>
<androidx.constraintlayout.widget.ConstraintLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto"
xmlns:tools="http://schemas.android.com/tools"
android:layout_height="match_parent"
tools:context=".MainActivity">
<EditText
android:id="@+id/editTextFirstName"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:layout_marginTop="100dp"
android:ems="10"
android:inputType="textPersonName"
android:text="First Name"
app:layout_constraintEnd_toEndOf="parent"
app:layout_constraintStart_toStartOf="parent"
app:layout_constraintTop_toTopOf="parent" />
<EditText
android:id="@+id/editTextLastName"
android:layout_marginTop="24dp"
android:ems="10"
android:text="Last Name"
app:layout_constraintStart_toStartOf="@+id/editTextFirstName"
app:layout_constraintTop_toBottomOf="@+id/editTextFirstName" />
<EditText
android:id="@+id/editTextEmail"
android:ems="10"
android:text="Email"
app:layout_constraintEnd_toEndOf="@+id/editTextLastName"
app:layout_constraintStart_toStartOf="@+id/editTextLastName"
app:layout_constraintTop_toBottomOf="@+id/editTextLastName" />
<Button
android:id="@+id/btnRegister"
android:text="Register"
app:layout_constraintEnd_toEndOf="@+id/editTextEmail"
app:layout_constraintStart_toStartOf="@+id/editTextEmail"
app:layout_constraintTop_toBottomOf="@+id/editTextEmail" />
<TextView
android:id="@+id/textViewFirstName"
app:layout_constraintEnd_toEndOf="@+id/btnRegister"
app:layout_constraintStart_toStartOf="@+id/btnRegister"
app:layout_constraintTop_toBottomOf="@+id/btnRegister" />
<TextView
android:id="@+id/textViewLastName"
app:layout_constraintEnd_toEndOf="@+id/textViewFirstName"
app:layout_constraintHorizontal_bias="1.0"
app:layout_constraintStart_toStartOf="@+id/textViewFirstName"
app:layout_constraintTop_toBottomOf="@+id/textViewFirstName" />
<TextView
android:id="@+id/textViewEmail"
app:layout_constraintEnd_toEndOf="@+id/textViewLastName"
app:layout_constraintStart_toStartOf="@+id/textViewLastName"
app:layout_constraintTop_toBottomOf="@+id/textViewLastName" />
</androidx.constraintlayout.widget.ConstraintLayout>
Wait! I got the forum's search feature to work, and I found the answer. You can display the time using a "widget": https://androidforums.com/threads/clock-clock.1119127/
-TC
OFFICIAL SITE of samsung.Is that the official charger or a 3rd party one?
Im not sure what else would need blue tooth in his case.
package com.ascenzi.usb_serial_testing;
import android.app.PendingIntent;
import android.app.Service;
import android.content.BroadcastReceiver;
import android.content.Context;
import android.content.Intent;
import android.content.IntentFilter;
import android.hardware.usb.UsbDevice;
import android.hardware.usb.UsbDeviceConnection;
import android.hardware.usb.UsbManager;
import android.os.Binder;
import android.os.Handler;
import android.os.IBinder;
import android.util.Log;
import android.widget.TextView;
import com.felhr.usbserial.CDCSerialDevice;
import com.felhr.usbserial.UsbSerialDevice;
import com.felhr.usbserial.UsbSerialInterface;
import java.io.Serializable;
import java.io.UnsupportedEncodingException;
import java.util.HashMap;
import java.util.Map;
//import okio.Buffer;
public class UsbService extends Service implements Serializable
public static final String TAG = "UsbService";
public static final String ACTION_USB_READY = "com.felhr.connectivityservices.USB_READY";
public static final String ACTION_USB_ATTACHED = "android.hardware.usb.action.USB_DEVICE_ATTACHED";
public static final String ACTION_USB_DETACHED = "android.hardware.usb.action.USB_DEVICE_DETACHED";
public static final String ACTION_USB_NOT_SUPPORTED = "com.felhr.usbservice.USB_NOT_SUPPORTED";
public static final String ACTION_NO_USB = "com.felhr.usbservice.NO_USB";
public static final String ACTION_USB_PERMISSION_GRANTED = "com.felhr.usbservice.USB_PERMISSION_GRANTED";
public static final String ACTION_USB_PERMISSION_NOT_GRANTED = "com.felhr.usbservice.USB_PERMISSION_NOT_GRANTED";
public static final String ACTION_USB_DISCONNECTED = "com.felhr.usbservice.USB_DISCONNECTED";
public static final String ACTION_CDC_DRIVER_NOT_WORKING = "com.felhr.connectivityservices.ACTION_CDC_DRIVER_NOT_WORKING";
public static final String ACTION_USB_DEVICE_NOT_WORKING = "com.felhr.connectivityservices.ACTION_USB_DEVICE_NOT_WORKING";
public static final int MESSAGE_FROM_SERIAL_PORT = 0;
public static final int CTS_CHANGE = 1;
public static final int DSR_CHANGE = 2;
private static final String ACTION_USB_PERMISSION = "com.android.example.USB_PERMISSION";
private static final int BAUD_RATE = 115200; // BaudRate. Change this value if you need
public static boolean SERVICE_CONNECTED = false;
private IBinder binder = new UsbBinder();
private Context context;
private Handler mHandler;
private UsbManager usbManager;
private UsbDevice device;
private UsbDeviceConnection connection;
private UsbSerialDevice serialPort;
private TextView t1;
//private Buffer buffer = new Buffer();
private String mode;
private boolean serialPortConnected;
* Data received from serial port will be received here. Just populate onReceivedData with your code
* In this particular example. byte stream is converted to String and send to UI thread to
* be treated there.
private UsbSerialInterface.UsbReadCallback mCallback = new UsbSerialInterface.UsbReadCallback() {
@Override
public void onReceivedData(byte[] arg0) {
try {
String data = new String(arg0, "UTF-8");
if (mHandler != null)
mHandler.obtainMessage(MESSAGE_FROM_SERIAL_PORT, data).sendToTarget();
} catch (UnsupportedEncodingException e) {
e.printStackTrace();
* State changes in the CTS line will be received here
private UsbSerialInterface.UsbCTSCallback ctsCallback = new UsbSerialInterface.UsbCTSCallback() {
@Override
public void onCTSChanged(boolean state) {
if(mHandler != null)
mHandler.obtainMessage(CTS_CHANGE).sendToTarget();
* State changes in the DSR line will be received here
private UsbSerialInterface.UsbDSRCallback dsrCallback = new UsbSerialInterface.UsbDSRCallback() {
@Override
public void onDSRChanged(boolean state) {
mHandler.obtainMessage(DSR_CHANGE).sendToTarget();
* Different notifications from OS will be received here (USB attached, detached, permission responses...)
* About BroadcastReceiver: http://developer.android.com/reference/android/content/BroadcastReceiver.html
private final BroadcastReceiver usbReceiver = new BroadcastReceiver() {
@Override
public void onReceive(Context arg0, Intent arg1) {
if (arg1.getAction().equals(ACTION_USB_PERMISSION)) {
boolean granted = arg1.getExtras().getBoolean(UsbManager.EXTRA_PERMISSION_GRANTED);
if (granted) // User accepted our USB connection. Try to open the device as a serial port
Intent intent = new Intent(ACTION_USB_PERMISSION_GRANTED);
arg0.sendBroadcast(intent);
connection = usbManager.openDevice(device);
new ConnectionThread().start();
} else // User not accepted our USB connection. Send an Intent to the Main Activity
Intent intent = new Intent(ACTION_USB_PERMISSION_NOT_GRANTED);
} else if (arg1.getAction().equals(ACTION_USB_ATTACHED)) {
if (!serialPortConnected)
findSerialPortDevice(); // A USB device has been attached. Try to open it as a Serial port
} else if (arg1.getAction().equals(ACTION_USB_DETACHED)) {
// Usb device was disconnected. send an intent to the Main Activity
Intent intent = new Intent(ACTION_USB_DISCONNECTED);
if (serialPortConnected) {
serialPort.close();
serialPortConnected = false;
* onCreate will be executed when service is started. It configures an IntentFilter to listen for
* incoming Intents (USB ATTACHED, USB DETACHED...) and it tries to open a serial port.
@Override
public void onCreate() {
this.context = this;
UsbService.SERVICE_CONNECTED = true;
setFilter();
usbManager = (UsbManager) getSystemService(Context.USB_SERVICE);
/* MUST READ about services
* http://developer.android.com/guide/components/services.html
* http://developer.android.com/guide/components/bound-services.html
@Override
public IBinder onBind(Intent intent) {
return binder;
@Override
public int onStartCommand(Intent intent, int flags, int startId) {
return Service.START_NOT_STICKY;
@Override
public void onDestroy() {
super.onDestroy();
serialPort.close();
unregisterReceiver(usbReceiver);
UsbService.SERVICE_CONNECTED = false;
* This function will be called from MainActivity to write data through Serial Port
public void write(byte[] data) {
if (serialPort != null)
serialPort.write(data);
public void setHandler(Handler mHandler) {
this.mHandler = mHandler;
private void findSerialPortDevice() {
// This snippet will try to open the first encountered usb device connected, excluding usb root hubs
HashMap<String, UsbDevice> usbDevices = usbManager.getDeviceList();
if (!usbDevices.isEmpty()) {
// first, dump the hashmap for diagnostic purposes
for (Map.Entry<String, UsbDevice> entry : usbDevices.entrySet()) {
device = entry.getValue();
Log.d(TAG, String.format("USBDevice.HashMap (vid:pid) (%X:%X)-%b class:%X:%X name:%s",
device.getVendorId(), device.getProductId(),
UsbSerialDevice.isSupported(device),
device.getDeviceClass(), device.getDeviceSubclass(),
device.getDeviceName()));
int deviceVID = device.getVendorId();
int devicePID = device.getProductId();
// if (deviceVID != 0x1d6b && (devicePID != 0x0001 && devicePID != 0x0002 && devicePID != 0x0003) && deviceVID != 0x5c6 && devicePID != 0x904c) {
if (UsbSerialDevice.isSupported(device)) {
// There is a supported device connected - request permission to access it.
requestUserPermission();
break;
} else {
connection = null;
device = null;
if (device==null) {
// There are no USB devices connected (but usb host were listed). Send an intent to MainActivity.
Intent intent = new Intent(ACTION_NO_USB);
} else {
Log.d(TAG, "findSerialPortDevice() usbManager returned empty device list." );
// There is no USB devices connected. Send an intent to MainActivity
private void setFilter() {
IntentFilter filter = new IntentFilter();
filter.addAction(ACTION_USB_PERMISSION);
filter.addAction(ACTION_USB_DETACHED);
filter.addAction(ACTION_USB_ATTACHED);
registerReceiver(usbReceiver, filter);
* Request user permission. The response will be received in the BroadcastReceiver
private void requestUserPermission() {
Log.d(TAG, String.format("requestUserPermission(%X:%X)", device.getVendorId(), device.getProductId() ) );
PendingIntent mPendingIntent = PendingIntent.getBroadcast(this, 0, new Intent(ACTION_USB_PERMISSION), 0);
usbManager.requestPermission(device, mPendingIntent);
public class UsbBinder extends Binder {
public UsbService getService() {
return UsbService.this;
* A simple thread to open a serial port.
* Although it should be a fast operation. moving usb operations away from UI thread is a good thing.
private class ConnectionThread extends Thread {
@Override
public void run() {
serialPort = UsbSerialDevice.createUsbSerialDevice(device, connection);
if (serialPort != null) {
if (serialPort.open()) {
serialPortConnected = true;
serialPort.setBaudRate(BAUD_RATE);
serialPort.setDataBits(UsbSerialInterface.DATA_BITS_8);
serialPort.setStopBits(UsbSerialInterface.STOP_BITS_1);
serialPort.setParity(UsbSerialInterface.PARITY_NONE);
* Current flow control Options:
* UsbSerialInterface.FLOW_CONTROL_OFF
* UsbSerialInterface.FLOW_CONTROL_RTS_CTS only for CP2102 and FT232
* UsbSerialInterface.FLOW_CONTROL_DSR_DTR only for CP2102 and FT232
serialPort.setFlowControl(UsbSerialInterface.FLOW_CONTROL_OFF);
serialPort.read(mCallback);
serialPort.getCTS(ctsCallback);
serialPort.getDSR(dsrCallback);
// Some Arduinos would need some sleep because firmware wait some time to know whether a new sketch is going
// to be uploaded or not
//Thread.sleep(2000); // sleep some. YMMV with different chips.
// Everything went as expected. Send an intent to MainActivity
Intent intent = new Intent(ACTION_USB_READY);
context.sendBroadcast(intent);
} else {
// Serial port could not be opened, maybe an I/O error or if CDC driver was chosen, it does not really fit
// Send an Intent to Main Activity
if (serialPort instanceof CDCSerialDevice) {
Intent intent = new Intent(ACTION_CDC_DRIVER_NOT_WORKING);
} else {
Intent intent = new Intent(ACTION_USB_DEVICE_NOT_WORKING);
} else {
// No driver for given device, even generic CDC driver could not be loaded
Intent intent = new Intent(ACTION_USB_NOT_SUPPORTED);
private UsbService usbService;
Button swchBtn = (Button) findViewById(R.id.buttonSwitch);
swchBtn.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick (View v)
if(usbService != null)
Intent swIntent = new Intent(MainActivity.this, SecondActivity.class);
swIntent.putExtra("USBService", usbService);
startActivity(swIntent);
Thanks again. I'll look for something similar.i believe i was able to control my phones camera using my gear s3 frontier watch.....not sure about other apps or devices that might do want you are asking.
