The number of destiny
The game is a transfer of the notebook version of the game 'The Number' from my childhood.
The playmaker had his notebook with a list of numbers under which the data was written in succession by categories.
In the application, the quarterback does not have an insight into what is hidden under the given number on the list, which is why he can participate in the game himself.
Collect a group of friends, have fun, and laugh together from your destinies!
Laugh from your randomly generated life.
Help LG Stylo 4 - made and received calls - other person heres echo
It happened to me on my volt 2 AND my Stylo 3. Both times were resolved by changing phone cases. I was getting feedback and echo from the ambient mic they use for noise cancelation necise the case was too close to it...or so I read. Whatever caused it...changing cases did it for me twice. Soooo...IF ur still getting echo or feedback, try it without the case and see if that helps.
Help Cannot mount /data in twrp
The first problem that I encountered was when Messenger started crashing after opening non-facebook links. Then I noticed that Gmail kept crashing a couple seconds after opening. I tried to clear Android AppView cache, data, Gmail's cache, app data, uninstalling updates but the problems were left unfixed.
I found a post suggesting wiping data partition, but that couldn't be done. I tried to repair /data, unfortunately I got error 8. Is it possible that I didn't root my phone correctly? If yes, should I try flashing again?
Help My Korean SK Telecom S9+ missing features
I would be concerned about having a strategy for updating (for security reasons)
what is your security patch date? (on at&t, mine is 6/1/19).
will your carrier support updating this phone? I doubt it. if not, rooting might be the only way to keep up to date. rooting is possible in the exynos versions of s9+ sold outside the us, but it may also come with some problems like screwing up some banking apps, risk of errors, etc.
How to fix ConstraintLayout inside ScrollView is not scolling?
Hello,
My App contains many buttons, which are shown under each other, two per row. I generate the buttons dynamically via Java, which are them shown in the ConstraintLayout.
Code:
<?xml version="1.0" encoding="utf-8"?>
    <ScrollView
        xmlns:android="http://schemas.android.com/apk/res/android"
        xmlns:app="http://schemas.android.com/apk/res-auto"
        xmlns:tools="http://schemas.android.com/tools"
        android:layout_height="match_parent"
        android:fillViewport="true">
        <androidx.constraintlayout.widget.ConstraintLayout
            android:layout_height="wrap_content"
            android:id="@+id/rootLayout"
            </androidx.constraintlayout.widget.ConstraintLayout>
    </ScrollView>
I have tried several layouts beside the ConstraintLayout, the TableView scrolling worked, however the button are not in the correct place then.
This is how the buttons are generated:
Java:
Button b = new Button(this);
            b.setText(myClass.getTitle());
            b.setTextColor(0xFFFFFFFF);
            b.setX(buttonX);
            b.setY(buttonY);
            b.setWidth(buttonWidth);
            b.setHeight(buttonHeight);
            conLayout.addView(b);
GPS Issue
Can you get a fix and location using GPS Status? If you can then the problem is in your map app. If you can't then it's probably a problem with the location system itself.
In the latter case, try setting location to "device only", which uses GPS only (not "battery saving", which doesn't use GPS, or "high accuracy", which uses GPS + network). This is just to eliminate one possible source of the problem. Test it somewhere where you aren't surrounded by tall buildings (which can cause problems by blocking or reflecting signals). If it works there then your GPS itself works, so the problem is either the environment or the network-based location. If it still doesn't then I'd see about getting the phone replaced under warranty.
I am new. Made my profile. I have new Samsung Galaxy
New samsung Galaxy (after owning 5 Samsung Tablets) forced me.. it felt like... to open a Samsung account! Never did that before. I gave up, created acct., put in my pay info for Samsung 'store'... which I only do for Google, Amazon. After I created account, read all the terms of use, EULA info. etc. Etc...you guessed it-- ALL is Samsung now.
Y'all.. I had to buy something for new ' Oculus Go'... because other devices too expensive. Even all Smart phones. I saved 128.00 by this purchase.This model is a 2019 SM-T380. On sale: 165.00.
So! I have read how everyone is getting ambushed too--w/ following bs. It has 3 competing software.. that just TAKE OVER my Google set up. I know Or I hope.. can get on hard drive and delete Samsung account, yada yada. BUT... I have feeling this will be punitive!! IF I DELETE SAMSUNG acct.. I cant use any of their info... isnt that their loss.. throwing away baby with the bath water? HELP!!! Going to bed finally.. maybe I can get some responses from this diatribe on my otherwise beautiful device? Katie
Filter
