Android 10 name
I'm running 10. Have to admit that as a user it's not so different, though the dark theme (black rather than "meh grey" thankfully) and finer permission control are nice.
The gestures aren't well designed (they slow app switching as well as interfering with side menus), and some crazy idea of integration with their own launcher means that the home gesture doesn't work with anything else. Allegedly this will change some time after the release, but they are definitely not good enough to suffer the Pixel launcher in order to have them. ;)
Help LG Update Tool won't install
I tried editing the build prop to spoof my android version so snapchat will work, but it didn't fall for it :( and now the phone has stopped booting.
It's impossible to spoof the latest Snapchat to run on Android 2.3.4 Gingerbread. Snapchat has code that prevents it from running on old android versions.
Maybe you might get lucky trying the oldest version of snapchat you can find. In the following link at the bottom there is version 3.0.1. Try that one and see what happens...
https://snapchat.en.uptodown.com/android/versions
Crash Reports
Weird, got a crash today and it wouldn't SEND the report - the send option was grayed out! But I had a couple other crashes that I sent reports for and still nothing.
Looks like I can view the logs from the "send report" screen, so I got what I needed from there. "Send Feedback" just closes the send report screen.
Still not sure why I'm not getting the report, but I published an update with a fix for this problem, at least.
Rooting newer devices
Is there any tool that makes it easy to root newer devices without needing a pc or expert moddong skills
Well just remember as newer phones comes out, the security for them advances along with the technology.... so it does get harder to root phones. As of now there is no easy method like those one touch apps from the past. But done manufacturers have still left it easier to gain root...... such as the pixel phones.
plus learning how to root you will gain some understanding and knowledge. If something goes wrong with the one touch method via an app, you will not have the knowledge to recover your phone.
This is one reason why this forum exists. If you have questions on rooting or need help with it, you have us here for help.
Main thing before you root, do your research before diving in to rooting your device. Be prepared and you should be alright.
Help Phone charging issue
If you're having a problem with a loose connection between the USB port and the plug end of USB cable, that's a hardware issue. When you plug in your USB cable, it's held in place by friction fit. Since you tried different cables it's very unlikely the plug end on each has wore down the same way.That would indicate the USB port being the issue. Some phones do have things like the USB port being modular and readily replaceable, but most of them involve a matter where the USB port is soldered directly to the motherboard. Phones may appear to be roughly the same in appearance but internally they are very different with a really wide range of varying hardware configurations. What phone model you do have?
Error: Invoke-customs are only supported starting with Android O (--min-api 26)
As myself and my collegue running same android code in different os.when my collegue run the code in ubuntu() its code was successfully running.
he shared the code via bitbucket i am cloning same code and try to running in win10 but i am facing following error throw:-
stacktrace
com.android.builder.dexing.DexArchiveBuilderException: Failed to process H:\projects\zinx-player1\app\build\intermediates\transforms\instantRun\debug\0
com.android.builder.dexing.DexArchiveBuilderException: Error while dexing.
com.android.tools.r8.CompilationFailedException: Compilation failed to complete
com.android.tools.r8.utils.AbortException: Error: Invoke-customs are only supported starting with Android O (--min-api 26)
i verified the following link to check version compactblity everything.but not clear my issue
https://stackoverflow.com/questions...-supported-starting-with-android-0-min-api-26
my basic config:
android {
compileSdkVersion 28
buildToolsVersion '28.0.3'
defaultConfig {
minSdkVersion 16
targetSdkVersion 28
renderscriptTargetApi 28
vectorDrawables.useSupportLibrary = true
applicationId 'com.arun.carapplication'
versionCode 170
versionName '1.2.0'
multiDexEnabled true
My Droid is possessed! FM Radio randomly shuts off and turns on.
I disabled the melody app and the phone stopped doing this! It was the MELODY app
GO into settings; apps; tap radio app or in my case MELODY APP; tap stop notifications= this stopped an auto trigger and Shake awake mode as well. You can also control this app through gadgets and widgets and yes, Bixby is a part of the interaction! Both Google Assistant & Bixby spy on you to bring the content that most interests you and you'll notice it when you go on to your Google and it will start suggesting things for you out of the blue that you've been talking to your friends about! Bixby isn't as invasive as Google Asst.
Help Transfer Apps from PC to Phone
you're not going to be able to install windows apps onto your phone.
If its an android app, the easiest way it to search for that app using the play store on your phone. It will then install automatically for you without any problems.
IF you found the android app using your windows device AND IT IS NOT in the playstore. I would strongly advise against installing that app.
There is a significant risk that it is compromised by some 'dishonest' person before you downloaded it.
Best advice is to avoid those.
Reserve the Samsung Galaxy Note 10 now!
Enjoy your phones! I was talking myself OUT of upgrading up until the very last moment when I finally calculated that with trade in, my payments for the Note 10+ would be less than my payments were for the the Note 8 (by almost $10 a month). I had one payment left on the Note 8, so Thursday, I paid that, and completed my pre-order around 10 p.m. EST
I'm with Verizon - and my notification says it's not shipping until 9/10. Ah well - I just remind myself I wasn't going to have it at all if I'd successfully talked myself out of upgrading and waiting until next year. I can wait a few more weeks and live vicariously through the rest of you guys! Congrats on your new phones!
Crazy though HOW delayed it is just by being a procrastinator!
Help How to clear the notification on the top taskbar
Well if you name the app someone might know whether this is normal for the app or not.
In general message notifications clear when you read the message - this works fine for email, SMS, even Facebook notifications (Facebook is my go-to example of a poorly-written app: it's quite happy to post a notification for a story that you read an hour ago, which is one reason I turn notifications off for the wretched thing). So if this app isn't doing that the best advice I can give at the moment is to contact the app developer, since it sounds like they are not handling notifications correctly (or at least not in the way you expect. There isn't a system setting for this, the app developer has chosen how they are cleared (or not), so unless there is a setting in the app it will be up to them to correct it.
Knock Off Battery?
Samsung electric corporation no long makes Note 4 batterys and most likely the battery you purchased was a fake. Also, the slim high capacity advertising 5690amh with the same size as the original are also untrue. The Acesoft battery is ok but I can say Id recommend it but its works. The external battery pack integrated into a case I would recommend. Its a Stallion. About the size of an Otter box only a bit heavier.
Filter
