wetbiker7
Extreme Android User
But then if you hit ##7678#, you get a data port menu with the options: {DM & UMS}. What's the difference between the 2 menu's?
I'm not sure. If you find out plz let me know.
Google is your friend
Oh trust me, I know. I just haven't found a straight forward answer.
That's the screen that lets you take it out of USB mode and put it in UART mode and it'll read on a COM port so you can use programs like CDMA . Then when you are finished using CDMA you will need to go back in to the menu and change it back to USB mode.
The script that MONSTER made for CM7 and the newer CTMods is much easier to use.
I have tried on both the CDMA Worshop 2.7 and 3.8 and receive error message (Failed to write PRL for NAM1 - I tried NAM2 this is using CDMA 2.7) and (Process is stopped. Device does not answer - using CDMA 3.8.3 trial.) It connects via COM3 and COM5 unlocks the phone and then it will not write the PRL file.
on ##7678# my phone was originally on uart. changed to USB to read port. changed back to uart after prl change. this seems to contradict what your saying so I'm not sure what correct settings are now. on ctmod 3.6 currently and setting said uart before I restored like it did when I first open that menu in stock
did you see my edit?
and you should change name to DryPedestrian
anybody else ever notice prl changing even though say fail? never did that month ago. yesterday I wasnt at ideal cellular hacking terminal
u nerds should get kick out of this:
laptop made for windows 2000
but running windows xp sp3
with partial (offline USB updater) updates due to lack of LAN hardware and no wifi capabilities. just phone jack for modem....
64mb ram
5.6gb hard drive
1 USB port
PS/2 mouse
it won't even boot without pagefile cuz ram below XP minimum (found out hard way)
haha I know it's sad. my desktop is a beast but it's in storage. that may have been issue but I don't think so since I was still able to connect to port and send password.
so ya people that fail to write to NAM1 check if it false error
it was 11111111119 so it newer.
Hey folks!
Latest PRL from sprint as of 3/20/2012 is 60686 (BatonRougeBroadband.Info - Home)
If any of you want to download it you can get it from here: 60686.prl
(source @Rob4828 thanks [UPDATE: 3/6/12] PRL Testing Thread [WIP] - Testers Needed! - Page 23 - xda-developers)
i have some old laptop memory pc100 if you need it pm meanybody else ever notice prl changing even though say fail? never did that month ago. yesterday I wasnt at ideal cellular hacking terminal
64mb ram
5.6gb hard drive
1 USB port
PS/2 mouse
i would like you to guide me to get the 4g speeds
