can i get a link to download boost prl....just in case i wanted to go back the original prl
i manually changed my prl using cdma workshop,added some build.prop 3g tweaks and i enabled 4gv vocoder and my download speeds are awesome.my download speeds before any tweaks was ranging from 300kbps to 400kbps and with tweaks applied from 1300kbps to 1984kbps all most 2mbs. Heres is a screenshot.
Tutorial
Tested on gingerbread should work on froyo but will not work on cm7. Disclaimer although all the tweaks listed here should not do any damage to your phone. if you do not know what your doing you may or can cause damage to your phone. do at your own risk.
how can i put the phone in DM or even get to the hidden menu now on GB 2.3.6 with CTMOD 3.2 and KK 2.0. all i want to do is change my PRL and i cant.
##3283# Does not work anymore with CTMOD... has this happen to anyone else?
If you are going to ctmod 3.2 , you won't be able to tell because you can't get in to the hidden menu . I think the proxies get reset when you flash a different ROM . I do know that the PRL will stay the same though .
The unlimited data helps me out . I've tethered the phone to my laptop and downloaded over 10gigs of data one a month before. I don't normally use it that much but It's nice to know that it's there if I need it . Only a couple more payments and I'll be at $35 a month and that's REALLY nice too .
Your signal strength and using 3g during peak user hours will affect your speeds too . I usually get decent 3g speeds where I'm at as long as I'm running the old EJ06 modem . The FA19 modem update really killed my 3g so I reverted back to the EJ06 modem by using Odin to flash the EJ06 phone.tar .
I use fast wifi now also but like I said , it's nice to know that the unlimited data is there for download if I need it .
I've managed to get mine to max out at 1.5mbp/s at one point. I only get those speeds at night though. Most other times it's between 200-500 kbp/s on average. I guess the coverage area for 3G in my small town is on crappy towers or something. I guess I won't see any benifit to the PRL changes until I go out of town to a nearby city where they likely have more cell phone towers to choose from.
Also, for any of those fiddling with the proxy settings. Don't just clear them out. Put zeros for the port and 0.0.0.0 for the IP. If you clear them out so that they say "Not Set", then apps that use streaming video like Youtube and WeatherBug will mysteriously stop working. You've been warned!
uploading stuff to facebook... sending mms... moving stuff to your dropbox. :thumb:Thought I would post that while I am not certain that I received any benefit in pull (download) data, I have noticed a definite increase in push (upload) data with this thread implementation (from 50 to 500k on averages).
I previously utilized the 0.0.0.0 fix.
Downside: is there much reason to increase push data from a Prevail?
Was on CtMod 3.5 fa19. Tried and tried but CDMA workshop wouldn't read my phone.
The reason was because I couldn't go into DM mode to unlock it. I believe. using the scripts and every method I could try just wouldn't work. It would never give me the option to enter my MSL to unlock.
So today I decided to ODIN back to stock GB Ej06. This worked great.. although a bit of a pain. was able to dial ##....# and enter my msl. CDMA worked finally and was easy.
I switched PRL 60686 then installed ctmod3.5 again. I just tried CDMA workshop again just a minute ago now that I'm on CTmod 3.5 but on ej06 and was easily able to change PRL again to 11119. a little bit faster DL but twice as fast uploading.
So cool, at least I won't have to ODIN back if I want to change PRL again.
