Root 1984kbps!!speedtest.net results after a couple of tweaks
komajutsu step 1-2 is not necessary if your on gingerbread. to get gingerbread on DM mode for cdma workshop to read it you will have to dial ##port# or ##7678# and select DM your phone will reboot in DM mode and cdma workshop should be able to read the phone now. and do you mind if i copy your tut ill give you all credit ill just add my info in step two. and ill upload my build.prop so you can check it out.
Go ahead, copy it, fix it, update it.
I just listed what I did. And I'm not familiar with the ## codes that work on our phone so I had no clue :)
I have no access to the hidden menu because I am running Hroarks Cm7 however I was able to get 2.18 Megs down using the 3g Turbocharger set to expiremental... Prl 60683 (with full service of course) ((and knowing boost full service is hard to come by in residential districts))
how did you change your prl with cm7? thats what im running and would like to change mine.
I downloaded terminal emulator and found my MSL that way. Much easier that way. And I did end up finding the port. It was labled under modems > SAMSUNG modems. But if I have to lose all my stuff to change my PRL I'd just rather not. It was a hassel the first time to do it all because I'm not that tech smart to begin with.
whats the serial port for our phone thanks
and do i need odin to flash my copy back or can just use cmw. dont know how to flash back via odin.
are you running gingerbread or froyo this will not work if your running cm7
GB CTMod 2.3 with Kouma 1.0 beta. This is all I know. A friend helped me set it up. I found my port. It's com4. I found my MSL number also. I Just have to search thru my computer for the adb file and see if I can piece this together, I did however change that EVRC-B and it didn't do anything so I believe changing my PRL will be the way to go. The only problem is finding one for upstate New York.
http://www.batonrougebroadband.info/Sprint_11115.txt
11115 should be good for you
Thanks but i'm still having trouble getting adb from "one click root" to work and I can't find a cdma to download without strings attached. Any quick tips? I know I ask for a lot but i'm pickin up the pace and catching on so you wont have to tell me twice.
OK, so here is how I interpret what all these tweaks do.
Vocoder change: This changes the encoding algorithm for voice encoding, potentially freeing up bandwidth for data
PRL change: Allows roaming connections to more towers that are outside your base network. This will improve signal quality only when you just happen to be near a tower that you couldn't use before.
Build.prop tweaks: Makes changes to data encoding allowing your phone to use more of it's available signal bandwidth for data communications.
Another thing that might improve speeds is the proxy setting tweak found in another thread. Those instructions would be cool to consolidate with this thread's instructions
How do i get MSL? I found a site that said run in emulator getprop ril.msl but did nothing
Then it says afeter a few trys permission denied
When in terminal use su to get root priv then issue the getprop. it will return your MSL.
Also case may be important with the ril.MSL param
Ok i can rom the shit out of my phone easy, im using guide to change PRL but what prl what file lol anyone have this stuff. never used CDMA workshop before....so very interested in trying this
CTmod 2.3......CDMA workshop v3.2.6 from some site says www.cdma-ware.com on top
Can anyone tell me where to DL sprint PRL's?
NVM found one.. DID prl to 11115.prl and the first thing and i hit 1.416MBp/s
debugging check, dm mode check, cdma wrkshp open check, found com port check (com prt 9), but when i try to connect i get a pop up message that says com9 available in registered version only! is there a way to change com port or am i just f'ed.:confused:
nevermind got it device manager, right clicked on samsung blah blah blah under com & lt, properties, advanced, bottum of window com port is listed click and change to a diff one close cdma reopen, reconnect usb cable BINGO!!!!
