jvasco2010
Rebooted and Wiped Battery Stats After it charged to 100 again....And its at 90 Gonna charge to 100 percent again and repeat until it stays at 100 after A Battery stat wipe... After that i should get Crazy life with this battery...If nobody has done this i suggest you do....Your tank isnt filling up
Also noticed that when i first got the battery it charged from 50 to 100 Pretty fast...Then it charged from 84 to 100 Fast but not as fast...Now its charging slow from 90 to 100....And seeing how big this battery is slow charging seems more realistic im heading in the right direction
Charging Through AC Not USB
Ok so been following this thread for a while now and I've had my eBay Chinese 3500 for few days and at first it was showing pretty crappy results. Less than oem for sure... I'm running fresh 3. 1 kings #9. I used nandroid recovery to wipebattery stats and found out itnever wiped it. I used clockwork and wiped it then turn in the phone and plugged it in... the battery level was at 73 and started to go down 1% every 10 minutes until it was down to 48%. Then started charging up again. I presume this is a fairly good thing I just hope I get good life now. Will report back.
