blkbeltkid17
Android Expert
Humm good question man couldn't hurt to try... I only use the gps weather anyways so it doesn't bother me
I'm running Invisiblek #28 kernel with Build #5 and it works great. I loved #21 with CM6.1 and #28 seems to be just as awesome with CM7.
Have you tried just flashing the ROM then checking sound settings without flashing anything else? You flashed a theme? Different kernel? Titanium restore? What radio you using? HBOOT version? Are you wiping cache partition and Dalvik as well as the factory reset?
There are so many variables that I would by trial and error try to find the solution and narrow it down. If it does not bother you that much than I would leave it be![]()
hey man are you getting usb tethering of any kind ??? i was looking into switching but on XDA they say other kernels will boink the tethering???
I don't have a need to use tethering so I've never worried about this functionality. I would stick with the OOTB kernel if you want everything to work.
i think it is that too and also you have to remember that not all apps are GB ready yet so it really could be any third party app that is throwing a wrench into your works
I re-downloaded everything from the Market rather than restoring through TiBU or MyBackupPro. My market links were apparently broken and not getting updated properly, so no wonder there was a conflict. Everything is perfect now.![]()
new fraimwere
Is there anything new in the most recent builds?
