And there you go!I don't use anything. I don't install anything with wonky permissions like record in call
Yes, but if you don't need it, why waste the space and bandwidth?avast runs fine on cm7
Found a recent review on cnet.com "Free Android antivirus apps fail to cut it" when I went looking for one. They did say virus protection on Android was mostly snake oil and the best of the worst was, the free app Zoner antivirus but even being the best it was only 32% effective.
Id like to know on what part of CNet you found that review. I fallow CNet and Avast. I seen nothing of what you say. Im not saying your making this up, just it doesnt seem true. At least by what Ive seen there is no review currently available by CNet for Avast mobile version.
Cut > Paste > Google > Voila Free Android antivirus apps fail to cut it
Although I don't see Avast mentioned.
If you took my quoted text, the article title, its the number 1 result on google
Free Android antivirus apps fail to cut it - Google Search
and it was from nov 15 2011, so I don't think avast got tested.
