Root Beats Audio
If you want to upload it somewhere, use mediafire or 4shared. I don't think anyone is going to be particularly pissed off unless they ask you to take it down, you know?
but if i were to post a link here, would it be violation of some kind of tos?
this does not work!!!!!
The link or the file? The file is the same one I used taken right off the sd card.. Either I didn't upload out right or I posted a bad link.. First time using 4 share so I'm not quite sure I set it up right.. Please let me know exactly what issue you're having and I will try to resolve it when I get back home to my laptop..
beats audio is a joke, and anyone who works in the audio industry(i mean as a REAL engineer, not the lop that sells you headphones at best buy) will tell you the same thing..you want more bass and clarity? learn to use a band eq..
fyi, if this software mod doesnt work for you..you can also try these...
DERP
DERP
While I agree with you, the mod does improve clarity and overall sound. Like for instance, my notification noise is way louder than it ever was pre-installation.
File is fine when i flash it it says abort and o . i have a lot of things for boosting sound i use power amp and volume + wich is the best one it also has a eq for speaker,headphone and blue tooth . it just boogles my mind i cant install it. i went to the xda page and tried every different file 4 of them and none of them work.
Has anyone tried this on the Admiral Beast? Also, I just simply unzip, install into the system folder on my phone, and that's it? Do I need to reboot? And if not all files copy it will still work correct?
Anyone? I'm wondering if there's any way besides having to get CWM to get this working on my phone and if it works with admiral beast without issues.
I'll try reinstalling, but does volume+ do the same thing this beats audio thing is suppose to do? You also mentioned something about this file's update binary not for the admire; does this mean this won't work on our phone period? If it does, I've never used CWM and don't really know how to flash things onto my phone lol.
I wasn't able to install Beats Audio via CWM flash either. Instead I just extracted the contents and manually installed it into the /system/ folder with Root Explorer.
I tried to do that but my phone bricked on the bootup screen. But i remember when doing that the /system/ wouldn't change to r/o. good times.
If this isn't for the admire, anyone have access to a working version of admire or an equal/better app for it? The sound quality on my admire could use a boost. I think I just successfully got the admiral beast rom on my phone.
Use equalizer and tweak it alot and it should work. But when using the equalizer DONT use 15.0+ on the equalizer, or your ears might die. :)
Also, as i've been asking, can anyone make a script do this? It doesn't matter if it'll take 2-5 minutes for the script to do it, as long as it works.!
Oh i mean a script from cmd - adb u know
When I get a minute I'll make it work for the admire.
