Root [Boost Mobile] BootLoader/Warp Drive
I tried to flash a rom, it got stuck, then I had battery heating up so after about 20 mns I pulled the battery, now all I got is the tweak nation boot logo, then Mr. Bobo's android logo, then the blue screen for TWRP. It stays on that, battery heats up, then I pull it.
So far I cant seem to get anything going but a semi boot up.
It starts to boot cyanoid, then starts to boot noobV1, then trys to go to recovery, TWRP, then just gets stuck right there. Battery starts heating, I get scared, Pull battery
Did you try shutting down the phone then manually opening twrp (same as opening the factory recovery or cwm)then factory reset nd then install a ROM from your Sd that you know works you might have had a bad flash this has happened to me before,if you still want to trythat ROM cool just download it again completely nd flash nd see if it boots
Yes, Shutdown because I pulled battery, trying to go for recovery but the phone wants to try and boot up instead. I'm deffinatly trying to get into TWRP!!:D
But the phone doesnt want to:(
Once you take the battery out leave it out for 10sec or so nd see if once you place it back in it dosent boot up then try to get into twrp again
Okay... why didn't you pm me?
What did you flash and what did you change? Where were you to begin with? Rom kernel.. you know the routine. :D
Ok little lass let me get all the info organized here.
Tried to flash a ROM
See both the kernel boot image and ROM boot image
Then it boot loops and starts over
Now is this what happens without trying to get into recovery?
Trying to get into recovery does the same thing, but sticks at the Teamwin image?
plug it into a computer and try an adb command if adb is working you can use adb reboot bootloader
then you can re-flash a recovery manually which should allow you access.
most roms in ATR use unsecure kernels so adb should start at boot. if you getting to the second boot logo then you should have a small windows of opportunity but that's a gamble to be honest
That's where I'm going. Just want to make sure it will get into taking an adb command first.
Edit: don't you just love how tapatalk quotes the wrong posts
I was back on noobVI 1.4hz DTM's kernal, I tried to flash cyanoid 2.1 and it went into a bootloop, would not install, battery started heating up, I waited, Finally got scared and pulled the battery.
Now, when I try for recovery, it wants to boot instead, but I see chevanlols tweak nation boot logo first, then I see Mr. Bobos black and white android logo, then it goes to the blue screen for TWRP, sticks right there, battery heats up, I finally pull the battery.
Thats where I'm at as of this moment.:mad:
Yes!! almost, Team win logo just sticks, unless I press the power button, then it starts over.:mad:
Ok wiat system? linux or windows, I have both.
how did you download cyanoid? was it re-downloaded or has it been on the sd since your first install? sounds like a corrupt download/badflash to me.
I downloaded from my pc then transfered it over to the sdcard later, I do it all the time but maybe it got corrupted
