panjwani_ajay
Can the debugfs method be used to root the Warp
This exploit works by symbolically linking the /system partition
While I'm trying to root my warp my screen stops at waiting for device. I clicked the debugging and unknown sources. Did I do something wrong?
Okay... I need help. How do you unroot the phone if I used option 1 specifically the clockwork mod one. I'm scared i don't know what im doing and id hate to destroy my phone. i need it for work and whatnot lol.
awesome.... is there anyway you can put it in simpler terms... im not tech savy at aallll. im surprised i got so far as to rooting it in the first place. haha. plleease?![]()
:thumbup:thanks ill give it a try and let ya know!
I used TWRP to root my warp recently and everything was good but I now keep getting a window saying there is a new system and software update. I do already have the B10 before the root. My question is, if I install the updates will it unroot the phone and will it erase all my data? Also can I use the TWRP method to root with the new updates?
I dont know how you used TWRP to root, but if you already have the updates then you dont need them again, Yes updating to B10 will break root, it's ok though because you can reflash TWRP and have root and custom recovery again,
http://androidforums.com/boost-mobi...0-based-viii-ii-full-install-1-23-2013-a.html
On the third question, Yes again, it will wipe your data and install massive bloatware.
If you want a custom rom just flash noob VIII.II. That will give you all the updates without the bloatware, custom recovery, CWM not TWRP, and custom OC kernel. If, after that, you still want TWRP as your custom recovery, just flash that file. Link above.
If you do not want a custom rom, but the updates only without all the bloatware then flash the deodexed version of the update found here.
http://androidforums.com/boost-mobile-warp-all-things-root/675897-stock-b10-deodexed.html
Their is also another rom Based on the B10 update, fully functional and flashable found here.
http://androidforums.com/boost-mobile-warp-all-things-root/676102-b10-based-rom.html
Feel kinda slow...lol...Thanks!!!What method are you trying to do? I recommend the zip inthe op, just flash ot in recovery.
can someone make 1 clicks like this for MSI windpad enjoy 7 plus please qq
This was kind of a fluke for this one click method
Very rare this method works at all, even with the right scripts.
