How many people are using the 1.8ghz and have wifi issues? What are the wifi issues?
I don't know about you guys but none of the governors work for me and its just always at max value... It doesn't bother me as I have set up a variety of profiles as a work around but I'm wondering if I'm the only one... I'm running oc 1.2 but i had the same issue with 1.0...
What app, rom, etc are you using?
Anybody ever check out freedreno?
Any update on better bat life. I have a 4200 and im at less than 50% after 4 hours i dont think it should be dying that fast even with my internet or minecraft usage
I have a 3900 batt. 9am-100%, 8pm-65% => 11 hours (heavy use, including remote access to my home pc)
I keep mine set to 1.4 gHz, did have a profile for screen off but seemed to cause lag when screen came back on.n00b VIWhat settings are you using? I've been doing well using interactive and sio, but not that well.I keep mine set to 1.4 gHz, did have a profile for screen off but seemed to cause lag when screen came back on.
That's really weird. There shouldn't be any difference between pmi and boost as far as the kernel is concerned. Do you have set on boot selected? Because with 1.2 there is a script that sets the governor at boot. Try one of the betas in post 3
Cool. Id donate but my pockets are empty.
Did you figure out if you could make a kernel that was pre set to something other than ondemand?
Yes I did. Coming soon!
And like I said. I do not require donations! Thank you though :beer:
