Alsaces Daddy
Android Expert
That sounds good buddy. Been waiting on both. I hope all is well on your end. Been prayin 'n junk for you.
Waiting for the new update so I can test it out.
Hope most bugs are fixed.
Well it wont be available for some time unfortunatelyi will get it out as soin as possible though
Thats a pretty nice theme!! Its very cleanly executed, i like it a lot.
I see you stated that this rom only works on Bo8c but Im running on Bo1 and running just fine.In fact I havent any problems at all! Nice job. Just wanted to add more data.One more thing, can you make flashable zips from the other roms? Im having trouble trying the other roms.
What I mean is that your rom is a flashable .zip file and the other roms are nandroid,is what I understand. I dont know how to use those and been trying to follow the instrucrions on how to flash them but I dont understand where to put the folder or how the file structure should look like.I wanted to know if you could turn those roms into the same format as yours so I can just drop them on to the root of my sd card. Thanks in advance and thanks for your hard work.will hit the donate button when you figure it out lol
how to down grade to b08c
