@Bloodawn trying to reverse engineer a fix for the portal of your ROM to public mobile... would be greatly appreciated if you could get in touche with me, i need to know what tweaks you did to the phone, contact, telephony provider and contacts provider apks... thanks in advance... smartmanvartan@gmail.com
Just thought I'd drop in here and say my best benchmark with this Rom is 6113. 1.8 ghz performance/noop. Thanks for the Rom. Loved it on the prevail too!
Had this rom for like 2 weeks now it runs awesome nice and smooth no lag .. never use a CPU before looking forward to use it do you have anything that can explain it thank
You can add it into the setting menu of you have a computer. Just decompile, drop a smali file in the correct place, add a line or two in settings.XML and voila! Its alot less complicated than it sounds
I don't doubt that it CAN be ported, but thing is Bloodawn only ever said he'd do Prevail and Warp, and he wasn't gonna make any more ports. He has also moved to XDA, about a year ago I think.
Tried barnacle it always starts with errors about the WiFi driver and causes my WiFi not to turn on even after installing just says error I had to restore from recovery
