I was looking for a bios animation that does not have a different phones branding on it. I may just use the same one Bobo uses (it's plain, simple and static, does the job). I may try and edit it and overlay the name of the rom and a pic rather than the word "Android" if I can get around to it.
I wish I could figure out a way to get chainfire's live logcat animation to work, but his demo runs upside down, and I haven't been able to figure out a way to make it boot from a flash. I may just try and mod it so it flips and include it in data for people to install themselves once they flash the rom.
I flashed blue version on my wife's phone, then installed a lot of apps,... and she want purple version now, so I want to keep blue version for my phone and change to purple one the other. There is a way to make that change without loose everything ? maybe using ES File Explorer ?
A simple way would be to make a backup of blue version, copy backup to your phone, install purple version on wife's phone, and restore just data from backup of blue on wife's and full backup on yours. You follow me?I flashed blue version on my wife's phone, then installed a lot of apps,... and she want purple version now, so I want to keep blue version for my phone and change to purple one the other. There is a way to make that change without loose everything ? maybe using ES File Explorer ?
A simple way would be to make a backup of blue version, copy backup to your phone, install purple version on wife's phone, and restore just data from backup of blue on wife's and full backup on yours. You follow me?![]()
To where does the fourth screen shot corresponds? I liked that thing, but I can't find it in the rom.
Great work!
Very smooth and stable!
Never mind, that is the LMT, I have the apk.![]()
Bump for skinnyjeans theme! This is looking so sick![]()
With a tethering app.
Next version will probably have a built in interface in settings menu like in tigatron or pattf's rom.
Ok I was lost lol
If the services.jar has my code in it you should be able to create a shortcut using adw
Weird, the music player is the app bugs... the Scary governor does that when powernap script is enabled
