Root [Boost Mobile] [ROM] HaloBean 9 FINAL (SkinnyHALO Included)
New Name?
  • Total voters
    60
Downloading now Skinny!! Same problem though, 18.5 or slower KB/S Same thing with Drop Box and Media Fire as well, Took me forever to get CM10!!! Anyway, I'll get it installed sometime later tonight after it finally finishes downloading. All three file sharing sites are slow as hell on downloads, dont know why.
Maybe I need to add a direct link.... how did i2f do it with his downloads?
Is it possible to put CPU speed in system settings menu in next update? If not how do you do it?
I tried that before, I personally don't think it's very efficient since the apps that support being added into settings as am option don't support an init.d script to set the speed. Rather, the app starts up on boot eating ram like I eat pepperoni pizzas at Cici's pizza. Voltage control can't be added into settings unfortunately, but I believe it to be more efficient than SetCPU. Sorry Danzo...
I just added a testing section to the second post, go check it out if ya want the links to the latest ROM version with the latest bleeding edge features! Remember, not responsible for bricked phones or the apparition of dragons and unicorns destroying your home because of flashing this or not following the instructions or installing it on the wrong device.
Good news! Remember how I said I wanted to make the rom zip smaller??
I did it!
Its now a WHOLE MEGABYTE smaller! :D
EDIT: Found out its only smaller cuz I forgot to include Lightning Browser haha... tested myself, running fine, but first boot has a low bench of 7397... I'll test second boot, if its past 8.1k then I'll keep building on this. I need others to help me test battery life, in other words run it for a few days and then give me reports while I boost the speed and add in lost fixes since I used 4.3 as my base.
EDIT2: Second boot takes about 40.814 seconds, so thats one goal reached.
EDIT 3: I need people to flash each and every version of HaloBean/HaloJelly and take benches in Quadrant Standard. I want them done like this:
After a full wipe and flash, and after the phone starts up the first time, install Quadrant. Reboot, and then test the second boot. Then take a screenshot of the results and post them in this thread.
Until then, I will continue trying to boost the current release and add in fixes and stuff, so they can be added to the fastest release of HB/HJ. I'm sick in bed so I'm gonna be working on this all day, so hopefully after a couple of benches, we can have HaloBean 5 ready within a few days :D
I did it!
I flashed it this morning. Ran great all day. Then I flashed the performance & GPU zips. This thing is rocking! No problems yet. And working it over! :)
So far so good Skinny!! Flashed it last night, Battery is awesome, theme work looks great!! Rom is purring like a kitten!! This is a great build, really like it.
Here's my benchmark. By sb43
How long does it take the battery to drop 10 for y'all? I can't flash and test because I forgot I had some mods in my system that would've been lost if I hadn't had a nandroid... oh and can I see some benches pweeze? Quadrant standard please, and if ya can do antutu too that'd be awesome :)
cool, time for a second release:
jkjk, not yet. Probably in a few hours though. Gonna add lightning, more theme work, and performance boosts as well.
Your overclock is draining the battery go back to 1024 and it runs normal.....Good work with the rom......
I know, I'ts not really the overclock but the scheduler. I've gotta change it to sio, even though cfq offers better performance. And first few hours after flashing isn't so great as the 3rd or 4th day with the rom. Everything takes a while to settle in.
Thanx for clarifying that up.
Wow! You are on fire! Everything is running smooth. Battery is good. Love everything about it.
Thanks for your hard work and dedication on this!
Welcome! And battery is better than the last release, it just dropped 1% after about 3 hours hah so that's a good sign... and I fixed more stuff in zero point two so second test coming tonight. Also it boots up much faster, so two goals accomplished.
