Root [Boost Mobile] [ROM] HaloBean 9 FINAL (SkinnyHALO Included)
New Name?
  • Total voters
    60
Guys, I'm thinking of switching out the powernap script in the rom for the original one that locks the phone at 122 mhz with a bit of wakeup lag, but benefiting the battery massively. Y'all okay with this change? After this last overhaul, I'll add the current one in (no lag/less conservation) as an add on in the second post, along with tons of other add-ons since I'm all about customization.
The original 122mhz power nap script produced enough lag that I could not answer a phone call. The ringing would end before the phone woke up and I could answer - hence the 2nd script... Just FYI... Of course this was while testing WOEM. I never tried adjusting the values in the script while running your ROM.
In my rom there's wake-up lag but not like that :confused: I'll have to modify the values because the phone doesn't enter deep sleep at 248 mhz or whatever it's set to
Added the new gps configuration file in the testing section, PLEASE READ THE INSTRUCTIONS FIRST
I really need the testers to follow the instructions, otherwise this test won't be accurate. Also, you can test in one environment and others can test in the other environment, you don't have to do both but if you can that's terrific :D
After gps test, I'll most likely have maybe 80% of the overhaul completed. PurePerformanceX is most of the way integrated, and mms is hopefully fixed as well... what was the last update with fully working mms again? Halobean 7 RC5?
If I remember correctly, I think EVERYTHING worked in RC5.(including Candy Crush).
They suggested looking in dumpsters and recycle places lol
I think these posts sometimes go "way off track " of the original thread. Let's keep track of the thread, and if you want to start a one on reception, satellite dishes and dumpster diving, then start one. No offense, just saying.
He's kinda right, I think you should start a new thread for that and I'll definitely hop on it, since I need a signal booster at home. Such crap signal, can't test out GPS configurations myself... And if internet gets knocked out I can't even get on here to let y'all know I wouldn't be able to get in here for a while D:
Can't wait for this overhaul. Still running 6.2, but I figure I might as well wait for the final edition! Ya done good Skinny!
ROM sounds great and wanna try it out, BUT a hotspot is a must for me. If it does have one cool...if not, does anyone know of app (and it's settings), such as wifi tether, that works with it?
yah been a while since i've been to forums. i haven't been flashing anything on phone since i got galaxy tab 2. sorry just wanted to make sure
PurePerformanceX is now integrated into the rom, as well as a new GPS configuration that works really well for me, but I still need people to help me test that other config so I can see which is better... also last thing on my list is mms
ALRIGHT IT'S IN, now I'm just fixing permissions, then I'll add in my new gps configuration that I've been busting my head on fixing in my phone. It still needs a teeny weenie bit of work though.
After this is done, I'll add in a few add-ons over the course of the next few months so as to really customize the rom/phone/Warp before I leave to continue with my studies. I'm not abandoning the Warp scene, let me be clear, I just need a few months break so I can focus on school, as my grades are beginning to take serious hits in some areas due to lack of time balance.
None taken :D
I never pay too much attention to the apps in a rom any more lol. I flash it to make sure it works then I always mod the zip file and reflash flash it to have the apps I use and remove what I don't.
Are there any apps y'all don't use in the rom? I need to know before I begin this next step
i don't use much of the apps, i use gosms pro for sms, spotify for music, and other apps from google play store, the only app i ever use is the calculator from the list nothing else.
Go bare bones Skinny. We can get what we want. :-):-):-)
Slim her down, make her fast, and make it all work.
Thanks for all of your hard work!
