mercury0x000d
The ultra-modern operator
Reflash the rom is the only thing I can tell you, no one else knows why it's doing that, so reflash it...
I'll second that, I'm stumped too... best to try reflashing
This is exactly what threw me too.I know the only time that I see "disconnected" is when your in WiFi mode. Service and everything else on his phone is working. Bill paid, I'm stumped....
Instagram stopped working again can you check it out. When ever I go into the mentioned to pick the filter on the picture instead of the picture is a gray image and it freezes the phone.
Alright, so i had him do the full wipe/re-flash routine, and it no longer says "none" but says "disconnected". I had him turn the wifi on and off a couple times, thinking maybe there is maybe some kind of glitch in the phones service state (like some kind of wifi limbo), but no luck yet. so at least i've moved this one step in a direction that's hopefully forward. Thanks to everyone for their input into my little dilemna, i really appreciate the responses i've received to try and help me out
I don't know if you know this. (Sure you do but) its a little glitchie. Notice it when long press power. And the sound is way to quite. Its not bad other then that. Boot load is slow as well. But once it boots man is it quick.
Probably a problem with the app, not the romtry wiping the cache in app settings. That fixes my Google Voice dialer (I make calls over wifi sometimes at home, I live in a weird spot that gets crappy signal for about a 300 foot wide area and as soon as I step out of that area BAM freaking full bars EVERYWHERE!) but yeah sometimes it'll force close randomly and wipe cache always seems to fix it.
Does anyone else have problem with the dropbox app?...On wake up of my phone...( I have wife's flashed to this rom also )..I get the error of Dropbox failed to open..force close?...I get this at least 6-8 times a day....I don't use it..and need input on how to remove it..as it is part of the built in apps...I do not have the option to remove in applications.......Thanks in advance...
I want to know the difference between PowerNap and SetCPU. I am not an expert so I think that SetCPU is more flexible because have profiles but PowerNap is very easy.
Can someone give me a procedure to disable/enable PowerNap ?
Thanks
Thanks
Basically, PowerNap is a script to force your device to its lowest processor speed (this is the default, but it can be changed) when the screen shuts off, and restores the previous frequency upon screen-on. The same thing can be achieved with SetCPU (or any processor stepping app which supports power profiles) but this method entails adding an app and its various components (event listeners to detect when the screen goes off and on, an additional background-running task to actually do the work, etc.) into your system. PowerNap eliminates a lot of the overhead of this by instead using the already-existing init.d scripting function built into the Alien kernel to streamline execution. Think of it as a very specialized version of SetCPU running only one profile
Also - and I don't run SetCPU so I'm not sure - but I believe some apps of that ilk only support changing governors, not frequency. Again, I could be quite wrong there lol
Removing PowerNap on this or any other ROM is easy! Just use your root-enabled file browser to navigate to /system/ect/init.d2 and delete it from the folder. Done!
Wow Merc excellent explanation dude................![]()
Nicely said Merc!!I may want to ADD it to CTMod, but the rom is so finiky sometimes I'm afraid to!!
It's easy enough to try! I would recommend doubling the minimum processor speed to avoid lag on wake.
Hmm, then it defeats the purpose.![]()
Oh, and I've gotten permission from Guspeed to port his n00b themes to Warp OEM!
It's like Christmas all over again![]()
