Root [Boost Mobile] [ROM] Warp OEM 2.70
You know what this means... :)
The first update of version 2.50... toggles are almost complete! I have some work to do on them, but almost all more or less function as intended. Now that the toggles are in place, it seems to me that the title bar of the ROM (the part that says "Warp OEM" when you pull down the menu) is taking up too much room, so I'm getting rid of it. This means the clear button is gone now too, but swipe-to-clear is getting implemented, so no worries :)
I'll keep you posted!
Well, as you can see... WOEM now has working toggles! This is the typical LiDroid feature we're all familiar with here, with the exception that I removed the reboot and shutdown options since we already have those on the power menu - no need to duplicate things :) The title bar is removed as you can see, and the Notification Toggles option has been removed from the settings menu since the app-based version is removed.
Next up: swipe-to-clear!
I Just wanted to say thank you to mercury0x000d, ever since i've downloaded your ROM my phone is soooo fast!!!! i dont know how you did it but my text messages are always on time, no more delays, i can send videos thru text ( Couldnt do that b4). I'm just happy and thankful, cant wait for the new version!!!!
I just installed WOEM 2.10. I don't see the same toggles in pic?? Is this new??
I had to manually set it up the toggles, and it takes up 2 lines with large icons. I don't mind the 2 rows, but it also shows up in the notification bar at the top of the screen, where I see 2 arrows just taking up space....
its going to be on the 2.50 version, not available yet.
Yep, what he said :D
V
Thanks for the support :)
But, seriously, thank you! I'm glad you're enjoying it :) I'm just starting to implement the swipe-to-clear feature, but it's coming along steadily. Hopefully I can get the details worked out soon and get this puppy public!
Sweet. Glad to see you got everything working. Swipe to clear is easy compaired to the toggles. I still have hex code nightmares lol
Lol! I hear you :-)
I've been meaning to ask you, can I get a copy of DS 1.2.5 and 1.3? I think it might help to have a little reverse-engineering example for implementing STC lol
After an initial FC, Swipe-to-Clear is officially implemented and functioning on my dev unit!
:party:
It helps I guess if you copy the entire function body to the ROM... Android doesn't like only having half the story lol
Can't say that I blame it! :)
Development is rolling on, folks :D
:party:
Easy like Sunday morning lol
Enjoy :D
:party:
Has anyone else loaded 2.50??
I no longer see the clear button for the notifications toggle. Or is there a bug with my version?? I now have to swipe to clear all notifications.
Thanks!!
Thats a new feature in WOEM 2.5, he got rid of it :)
That's not good then!:( I get tons of notifications every time I sync email, fb, update apps, etc.
This would mean I have to swipe to clear 20+ notifications each time. I've used other ROMS with this feature and they all still have a clear all button. no? Before I updated, the clear button was there.
This was one of those decisions that looked good from a coding standpoint, but in practice isn't that great. I've been lamenting the lack of a clear all button myself, and have already started adding it back in. The only problem is... where will it go? To save space, I got rid of the ROM title bar in the dropdown menu... maybe it needs to come back too... *sigh*
Edit: Got it! :)
What about the CTmod one? It shows up inside the tray when there are notifications and hides when there are none. Might be worth a look ?
I wasn't aware CTMod (or any other ROM, for that matter) did this, but that's exactly what I did in the XML edit I just added to solve the issue.
While downloading an app, everything is as it's always been (as seen in the attachment during, below) with the addition of the missing title bar to conserve space. However, when the download is done and the installation notification appears, the button is displayed along with it (which can be seen in the attachment after) under the Notifications heading. So now you can swipe to clear or clear all.
Just as it should be :)
