Just got into CWM somehow...had to pop out the sdcard and power cycle the phone a couple times. Not really sure, but I just "wipe data/factory reset" it from CWM. Is there anything I need to do to remove the alien kernel and stuff and go back to stock so I can redo the whole rooting and everything from scratch?
Really no need to re-root, and all thatIf you have cwm, you can go from there, flash a rom or a nandroid backup!!
Whew, glad you got it back to recovery mode!!
I usually do a factory data reset.
wipe both caches,
Then flash back a nanny or the rom again.![]()
So I do "Wipe Cache" in CWM? I'm familiar with the flashing part though.
Wow! Thanks! super helpful. Phone should be back up shortly.
EDIT: PHONE WORKS. time to reinstall this rom. Hey Merc, where's the setting to fix the glitchy screen due to the removal of the limiter?
Nevermind, found the smoothness fix! Thanks again Lil! Been a great help![]()
Hey! This rom is super fast, but today I encountered a really, really bad problem. When I boot the phone it freezes on the blue "android" screen. I tried plugging it in to my computer, and it says that windows can't ID the device and it has malfunctioned. So I can't exactly adb reboot recovery on it. I have CWM installed and everything, but I can't access my sd card or CWM from my computer. It froze up and randomly rebooted as I was uninstalling UC browser. Any ideas how to fix it? I can't really afford another phone at this point in time...
Thanks
...and thanks for all the customer support while I was gone, LilBit!
Hey, first off welcome to the forum, and to my ROM!
This is just a thought, but how long did you wait on the blue Android screen? I know the first boot can take forever, and I'm thinking that maybe - just maybe - the freeze-up you experienced was just a loooooong first boot?
In any case, sorry it happened, and here's to smooth sailing from here on out![]()
Would work throttlefix.zip for Warp OEM 2.51 ? (because it is not a B08c based rom).
I replaced "30_SwapServiceStartup" script on "init.d" for "00zRam" (also on "init.d" but in Halo rom) then rebooted. I got an 6102 Antutu score after that. Everything works perfect, like before but seems more snappy.
New update!
Throttling functions are now removed from Warp OEM 2.53, available in the Download Center!
Enjoy![]()
