Root [Boost Mobile] Shinjitsu Rom 1.5.2.4 OTA Available(Discontinued)
Which battery icon do you like better?
  • 1.5b Battery Icon
    Votes: 7 31.8%
  • 1.5.1c Battery Icon
    Votes: 15 68.2%
  • Total voters
    22
  • Poll closed .
Status
Not open for further replies.
The rootdim not showing the flashlight can very well be from running that certain camera apk. I do recall testing other cameras and some take full control of that flash.
Agreed. However, at your suggestion I've been running this camera app for awhile now (love it, thanks bro!) and rootdim and Camera ICS+ ran fine on the WP7 ROM. Now we have no led. So add this to the list Shin! LOL
Correction: Camera ICS+ flash DOES in fact work with Shin's intermediate update on my phone. Rootdim is still a no though. My bad for the falsity on my prior post
I don't get it... how are you all having ANY problems? After installing the 1.5.1 alone, my phone was as stable as stock (actually, even more stable). I NEVER lost my signal after turning on wifi. My bluetooth has always worked perfectly. My LED flash light under the camera works good. I brag this ROM up to my best friend, and he is impressed greatly. Plus, I'm playing games that are 3d with no problems at all. I run it at about 1.24 GHz, and never have problems.
My 3g speed seems better. Maybe I'm hallucinating
Mine's still the same. Maybe you are hallucinating.
If I didn't need bluetooth where I live I would be all good. I'm also definitely not complaining. The ROM is still in the testing phase so we're making sure we do Shinru right by reporting the bugs. Sounds like you have it made! Right on! Besides bt, rootdim flashlight, and the "clear" notifications white out button in the status bar pulldown, I'm straight
Noones complaining its in beta for a reason im sure he wants to know of these bugs so he can make his rom the #1 rom for the warp (even though it already is) my only issue with it is the whole i cant do wifi and 3g at the same time. i use wifi to get on the internet at my house, yet at the same time would like phone calls / texts to work. it seems like if i enable wifi i cannot use 3g but if i disable wifi my 3g is back in action
I'm not having this issue, luckily. Are you running b08 or b08c? Just curious. I'm running b08 so if you are too then I'd re-run the process of installing from point A.
Shinru, can u plz clarify something for me?...ever since your first beta rom, they have been only 08b compatible, and as far as i can see....your listing the newest 1.5c as 08b ( b/c you still need to downgrade), yet i keep reading people on 08c wout problems....confused..
Im confused with your question, please excuse it, i've had my ZTE warp for a week haha.
edit: I was on B when i first started using ROMs, i went from WP7->Shin->about to go try that new guys non-oc ROM
I must be the only one who really doesn't find this to be an issue...maybe b/c im used to the crappy signal in my home but....even while im on wifi, ill get calls...ill get texts....
I flashed the latest ROM
an is working more stable than when a purchased the phone, the 3g lags as usual but I was able to install all the apps that I use. the only thing I see different is that the phone gets a little warmer.
to flash it, had to use the sd card that came with the phone, didn't take anything else.
thanks for getting rid of the stuff form sprint.
You only need to downgrade if you are restoring 1.5b from nandroid
Well you dont need 3g for calls or texts just plain service and as for this issue i dont seem to have any problem i installed this ROM on 08 i dont need to use 3g and wifi at the same time
Just wanted to say i have been using the rom for about 2 days with no problems at all. this rom is freakin awsome, lightning fast with the oc at 1400 and benchmarked at 3705. grats on a job well done my friend. best rom out thus far.
Any suggestions on why barnacle is having a "shell-init: error retrieving current directory: getcwd: cannot discover parent directories: permission denied." first time I've tried barnacle for tethering since dl'ing shinjitsu so this is new to me. Hoping its just my stupid error LOL
Status
