Ill check that out. I have a new build in progress right now. I could have just swapped the libs but i was feeling lucky
Network was set to 4 in the stock build.prop
hey, does this work on the zte z998 as well, the specs are the same as the z930l but i just want to be sure. thank you
New here. Have some knowledge with programing never used Linux tho.... I was a VGP major until finances failed tho....
Any who, I have a zte source(n9511) and can't make sense of how to get this ROM running where it reads sim card anyway I can get a little walkthrough as to how to fix sim error?
If not I'm sure I can make sense of past post's eventually....
Any help tho would be lovely.
Thank you c:
ok, so i flashed the rom on the AT&T Z998 and it is impossible to test as of now... the display is EXTREMELY distorted (including the boot animation). the rom flashed fine and everything went smoothly, it booted up pretty fast with the unico's version but the boot logo and the first-boot setup screens were horrible (the pixels seemed mixed/distorted along the horizontal) i am not sure why this is happening as the unico and the z998 have the exact same specs. the only difference is the physical shape with the camera. i have no idea how to fix this as i have barely any developing experience. thank you
Unfortunately, adb reboot bootloader simply reboots and bypasses the bootloader. I am able to boot into the bootloader by holding Vol+ and power, but it ignores fastboot.
ok here, as i said, i am kind of a noob so i just put in the entire build prop file. (this is a stock file that came with the device as is, i am still running the stock rom) i did see coeus as the name though...
also, i think it just may be the kernel, a friend of mine with dev experience suggested that as well. also, the straighttalk version is cdma while the z998 is gsm...
Mobile data is now working on the warplte. MMS fcs, and placed a call but no answer lol.
alright, when i flash it, it says something like "zte unico detected..." (something like that and i see your little title and credits and then it starts installing the system files.)
i rooted with framaroot (gandalf) and flashed the recovery image with terminal emulator...
this is where i got all the files and instructions...
[Root & Recovery] ZTE Mustang Z998
same guy also uploaded a "stoked" stock version of the rom... (didn't see much difference when i flashed it and i had data problems so i reverted)
[Stoked Rom] ZTE Mustang Z998
I've been watching to see if u guys got it working and I see your really chipping away at it.The awe is my daily driver so I need it functional. hate to bother anyone but is it usable?
