you can do it by installing google android sdk.
OR
you can do it by installing connect bot or some terminal emulator on your hero and running the command.
If you'll run it directly from phone there's no need to type adb.. adb - is the utility from sdk.
I still didn't found how to aplly this fix permanently.my is rooted, and it works.
I've intalled Better Terminal
then
su
then
ip link set tiwlan0 mtu 1300
and thats it.
The only problem for now is that you'll have to enter this command every time you reconnect to wifiI still didn't found how to aplly this fix permanently.
the problem was in hero's mtu setting.
Ok, I've now tried Better Terminal.
After the "su" it said "su: permission denied", but I put the "ip" line in anyway, and it didn't come up with an error. Does this mean it's done what it's supposed to do?
Just a word of caution here....
Confirm your router's MTU before altering anything on the Hero, as if the device MTU is set to a larger figure you'll simply compound any problems.
nothing terrible will happen as the mtu setting will revert as soon as you reboot or reconnect to the wifi network
Well, there's not a lot of point in doing it if you don't do it properly. Make the MTU too large and you'll have a major fragmentation problem to deal with, making your connection worse rather than better.
but the fact is that changing mtu solved my problem.. I don't see a reason why not to try...
In fact I think that this tweak actually solves fragmentation problem but not creating it..
my hero cant auto matically see my router but it can the neighbours, to connect i have to manually enter my ssid then my wep code.
