Hi guys, just wanted to let you know that I'm now browsing via Wi-fi on my Hero using my D-Link DI-524 router!
I found the solution over at xda-developers, where there's a thread very similar to this one. Some guy over there had a version 3.13b of the D-Link DI-524 firmware. Mine was running 3.12, which appears to be the latest official release.
Anyway, user deeren over at xda-developers kindly uploaded the 3.13b firmware he was using, and I installed it on my router and it fixed the issue!
You can find deeren's post with link here xda-developers - View Single Post - wifi signal, but no internet.
NOTE: deeren does point out that the 3.13b firmware is for the G2 version of the DI-524. I have no clue what the difference between the versions are, but mine was a G2. On the back of mine, on the white label it says "H/W Ver.: G2".
Furthermore, with regards to you guys running Zyxel routers. I stumpled across a thread on a Danish board, discussing this issue on an HTC Magic -- indicating that it's an Android/Linux issue -- and from that thread was a link to another thread at xda-developers claiming that new Zyxel firmware fixes the issue as well (though special Fullrate/other branded firmware may complicate the upgrade process). Here are the links:
Problemer med WIFI p
). Both Zoom and HTC advised that if you have any "n" settings then to turn these off as the HTC doesn't like them.
