trigger1074
Were you running the d version firmware? If so yes use the unbrick guide after doing a factory reset. The reset is very important![]()
How did you fix yours after the bootloop..Im stuck. I tried both firmwares
Did you do a hard factory reset before flashing the firmware?
Hey, wouldn't we be able to use the advanced restore function to restore the info from a back up of our ics?
what info? your angry birds levels?
Never touched angry birds.I'm talking about build.props and the system software.
all of which is in the system partition, where the rom is actually flashing :/
doing any restore will restore what rom you had (in this case stock)
any idea what apk will cause the issue of morning call? i removed some system apps in the deodexed version and flashed and am getting morning call. that leads me to believe that one of the system apk`s is in direct workings on the morning call error.
no idea youd have to ask someone who has the device and can experiment.
Not true, when you use the advanced restore you get the choice to restore parts of the rom.
I'm going to McDonald's. By the time I get back. The bootloader better be unlocked.
Anyone have a mirror for this?
For CM10?? The second link is working.
nopeGo to the second link and scroll down to file details, it says file size 0kb... I think horak got mad and took it down...![]()
