techmeister
using any themes?
None at all. Just flashed the rom and didn't install any themes or apps.
using any themes?
It is a possibility that you have a corrupt download. Download the CM7 zip again.
Just for good measure, I would use Odin to take it back to rooted stock.. (I WOULD USE EJ06 SINCE CM7 DOES NOT UPDATE) I would then install the CWM update.
SPH-M820-CWM-5027-UPDT-FIXED2A.zip
Then install CM7 (A NEW COPY) and then install 1 of the OC kernels.
Let the phone boot up completely after each individual flash.
One more thing, just to make sure that you cover all of the bases...... I would also wipe the sd card after using Odin to take it back to rooted stock. Then I would repartition the card once CM7 has been installed.
I don't know what kernel you are running but I ran the NON-EXT. version. I used S2E to transfer my apps to the sd card and it worked like a charm. Very very smooth running phone. Didn't even need to mess w/ any of the new SWAP stuff.
Good luck and I hope you get it working.
cguru:Are there any alternative kernels for this ROM?like an Overclockable one?
Yup katokernel
Where can I get katokernel?I don't see it here in the thread
Edit:is the /data partition still mounted on the sd-ext with kato?
This is awesome Hroark! Will download now. Thank you!![]()
He's not real, he is spam![]()
lmao!! What happened LV? How could you tell he was spam? I see that his comment has been removed too.
Just a heads up. If you are running a slower sd card, you may wanna use the non-ext version of the kernel and just run S2E from the market. I was even running a class 10 card and decided to run S2E. There is a big difference in the speed that you'll notice. S2E does away with almost all of the lag too. I've talked quite a few people in to doing the same thing and all are very happy with the results and can tell a big difference in speed and responsiveness.![]()
As LV said, you will lose all your apps. I always start fresh when installing S2E.
1)Install CM7
2) Partition sd card
3)Factory reset.
4)Install kernel
5)Install S2E and set it up. After install, go in to setting and check all boxes.
6)Reboot, open up S2E and check all boxes except data/data. You can check it if you would like but I find it runs better when it's not checked.
7) Install apps.
8)You now have 1 bad ass, fast as heck phone that will not get updates.
free
swapoff /dev/block/mmablk0p3
mkswap /dev/block/mmcblk0p3
swapon /dev/block/mmcblk0p3
Hows the battery life compared to my current setup?
@wetbiker.soooo much snappier.I followed those instructions.I'm impressed.beautiful.
