shamrock262
You can either delete it through titanium back up or with esfile go to /system/app and delete latinmeapk have to mount system as rw for it to work then reboot
Mount system as rw? Again, I apologize.
Ro means read only, rw read and write . So rw to do or change things. Also titanium from the store is great app to have and easy to use to wipe data, freeze and delete stuff. Like Wetbiker7 said.
mount /dev/block/stl13 /system/swap
dd if=/dev/zero of=/system/swap/swapfile
mkswap /system/swap/swapfile
chown root:root /system/swap/swapfile
chmod 0600 /system/swap/swapfile
swapon /system/swap/swapfile
swapon /dev/block/mmcblk0p3
echo "vm=swappiness=60" > /system/etc/sysctl.conf
Sorry to see you go biker.. I know you'll still be around but not being a prevail owner will make you eventually move on. I have a Transform Ultra and have been doing some deving over there for a while now but I just cant seem to deactivate the prevail cuz I just cant believe what this little phone can do now. I just use the TU for a dev phone. I guess i'll switch eventually when we have a full working cm7 maybe.Never tried app2sd I used s2e. The newest version works flawlessly. I just set up my ext, downloaded the app and opened it up then went in to settings and selected all boxes. I then backed up and selected everything but data. Worked like a charm and a lot better than the older version did. Glad you're still working on bettering the rom. I put it on my prevail for the guy I sold it to today. He loves it.![]()
why don't you make the swap with an init.d script?
edit: nevermind, i read the WHOLE post and saw that you mentioned it already.
I too have noticed that S2E seems to run much better now. It ran fine before, but it has been improved over the last few months.
Is cm7 still having issues with the speaker and speaker phone working
Why doesn't this have the theme Chooser anymore like the older version
I have found a small problem when it comes to downloading apps from Google play. In settings-about phone the model number of my phone is listed as SPH-M820, it used to be SPH-M820-BST before switching to cm7...I can't dl some apps because of the change of the model number, many that say compatible for SPH-M820-BST are listed as incompatible for SPH-M820.
Does anyone know a way to fix this?
Thanks
That's because the apps are not compatible w/ CM7. You will have a lot of apps that will only work with CM7 too.
Just because G Play says that the apps are incompatible doesn't mean that they actually are. Try finding the apps from another source and see if they will work. Sometimes they will and sometimes they won't.
Be very careful too. Make sure you do a CWM backup before trying an app that G Play labels incompatible . It may very well be incompatible with your ROM and lock the phone up.![]()
Ok, thanks for the explanation. I thought it was just an issue with the model# being changed.
I have been experiencing a strange problem. My signal strength indicator keeps freezing both the indicator in the status bar and the text dbm in settings-about phone-status.
I have tried uninstalling cm7, factory reset, clear dalvik cash, clear system cash, went back to stock reinstalled cm7 with no apps no themes and still have the same problem...tried it on FA19, FE16, CTmod and had no problems, but every time I go back to cm7 I have the same problem.
Any ideas?
Thanks
