nevermind i just reran smartbench and it gave me the same score as the froyo
based roms. sorry bout that
i wonder why the Quadrant score is so much higher
do you think it is a Quadrant glitch
i wonder whu the Quadrant score is so much higher
Is the Voicemail not connecting an issue that is known, i scrolled back a few pages and didnt see anything. If i click the notification or hold 1 for speeddial i just get ringing. If I dial my phone number i can get into it though.
Speaker button works without having to press mute. Person I'm talking to no longer hears echo. Also the speaker volume is louder. I don't have to hold the phone up to hear. I have been tested this on ingoing, outgoing and conference calls just to make sure. Great job.
I tested after install CM7 and gapps. Didn't want take the chance of something I installed to cause any problems. I'm about to add a2sd and was wondering if I need to change anything in Settings>CyanogenMod settings>Applications? Or should I leave it at default?
i was just wondering if the CIQ was removed or dissabled in this mod. i didnt notice mention of this
i dont know how to just get rid of it but if you flash cm7 ultra blue theme the roaming indicator is goneHey what about the Roaming Indicator Off how do I remove that? I read previous post didn't see anything...
However I am loving it, with Gapps that you had installed smoothly and everything is working fine, ringtones sound great
I know it off topic a bit but just wanted to share something I learned as well with this setting.setting - call settings - voice mail setings - voicemail number
erase *86 and put in your phone number
I was wondering this toohey just checking can I use the ultra blue theme with the v2d version of this???
How about a coffee!to be perfectly honest with you, I stopped drinking 7 months ago
so doing this Android stuff has helped me to stay sober, I was kind of out there for a while
but you can buy me a soda if you want, Diet Coke
saying, buy me a beer just sounds a lot cooler I guess
hroark, in Known Issues you mention that wifi hotspot is not working but we could download a free app. What is the name of the app u were referring to? Unless I have to make changes to the settings WiFi tether doesn't work on here (tried the dns settings mentioned) and barnacle is really slow and doesn't act as a hotspot like Wifi tether did.
How about a coffee!
So, Hroark
Everything on my phone seems too be running great! So, I have a question about your new version vs. dtap2sd! I had a heck of a time getting apps to acknowledge that there was an ext.04 So, will i loose ext04 when i flash your new beta? If so im gonna hang loose for awhile cause i dont feel like going through that again!
Thanks
Ric
